Power Commander question. - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 09-28-2010, 10:53 PM Thread Starter
I am buying a DMC Afterburner Complete Exhaust and I need an EFI. I keep seeing that the power commander 3 works with the 08 700xx (this is what i have), and the power commander 5 only works with the 09 700xx. Does anyone know if this is true, or if its even worth the extra cash for the 5 rather than the 3? thanks.
Britalican is offline
post #2 of 11 Old 09-28-2010, 11:47 PM
pc3 and pv5 will work on any year.... and un less ur gona get auto tune u dont need the pc5
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
post #3 of 11 Old 09-29-2010, 01:45 AM
The 3 and 5 will work on either machine. I am not too familiar w/ the 5, but I know with the 3 it is easy to get maps for it and set it up just b/c a lot of people on here have maps already.
post #4 of 11 Old 09-29-2010, 07:32 AM Thread Starter
Ok thanks guys. I just got a new pc3 online. Cant wait to get everything installed and take it for a spin.
post #5 of 11 Old 09-30-2010, 10:27 AM
If you go to the powercommander website they will have a few maps. I haven't seen anyone w/ ur exhaust, so I dont know how close it would be to getting a map for another full set up. But if you tlak to VelociRaptor, he may be able to hook you up. Just download the cd on ur computer and you should be good to go for setting it up. It is very easy to do. Also, on the PC3, the wires are short, so I put mine in a soap box to keep it dry.
post #6 of 11 Old 10-01-2010, 06:44 AM Thread Starter
Yeah I actually sent him a message the other day, but haven't heard back yet. I have searched the web and found almost nothing for the 700xx pc3. pretty disappointed about that.
08 Honda 700xx
Installed
post #7 of 11 Old 10-07-2010, 04:22 PM
i did to he said he isnt doing maps any more becouse no one would dyno them to prove the were on the right track.
post #8 of 11 Old 10-07-2010, 04:38 PM
boost addict's Avatar
You are just asking for trouble if you don't have it dyno tuned. Every quad is different. I learned the had way with my Rhino 700 efi and the pc3.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #9 of 11 Old 10-08-2010, 06:35 AM Thread Starter
dang that sucks. not sure what I'm gonna do now
08 Honda 700xx
Installed
post #10 of 11 Old 10-08-2010, 08:33 AM
droby1242's Avatar
buy a barkers and i have just the map for you!! lol any ways if you would have bought it from fuel moto they would have loaded a map. but you should spend the 250-300 dollars and get it tuned.
droby1242 is offline
