Ride full exhaust without EFI? - Club700XX - Honda TRX700XX Forum
post #1 of 22 Old 10-01-2010, 07:48 AM Thread Starter
So my exhaust should be here either tomorrow or saturday, and I am going riding on sunday. My pc3 hasnt even shipped yet. Is it a bad idea to install the exhaust and ride this weekend without the pc3? should I just wait? man that will be hard to do, since I probably wont be riding again until the end of october, and I really want to put that exhaust on. grrr
08 Honda 700xx
Installed
Britalican is offline
post #2 of 22 Old 10-01-2010, 07:53 AM
av8r's Avatar
You'll likely not notice any difference and it certainly won't hurt anything. If you want to see what it'll be like, pull the core out of the stock can.
av8r is offline
post #3 of 22 Old 10-01-2010, 07:59 AM
I was told to NOT run the full exhaust with out the EFI it will run HORRIBLE if you do, When I had my full exhaust first on I didnt have the efi set correctly and it ran bad, If you want to have fun when you ride and not have ur quad back firing or stalling? just ride it as is till you can install it all correctly
Captamer71 is offline
post #4 of 22 Old 10-01-2010, 08:20 AM
TRX700XXX's Avatar
Agree ^^^^^^ my full barkers exhaust came in before the controller and I turned it on just to hear what it sounded like and even idling it was all messed up and didn't rev right.
TRX700XXX is offline
post #5 of 22 Old 10-01-2010, 08:57 AM Thread Starter
Yeah I figured I should wait. I hear all the time that the xx runs lean stock, so it must run real lean with the exhaust =(
08 Honda 700xx
Installed
post #6 of 22 Old 10-01-2010, 09:13 AM
av8r's Avatar
pah!
Exhaust is for sissies....
av8r is offline
post #7 of 22 Old 10-01-2010, 09:39 AM Thread Starter
Originally Posted by av8r View Post
pah!
whats sissy about extra hp and torque?
08 Honda 700xx
Installed
post #8 of 22 Old 10-01-2010, 09:46 AM
av8r's Avatar
any exhaust at all is for sissies...I like to run it wide open to let the engine breathe properly!
av8r is offline
post #9 of 22 Old 10-01-2010, 04:28 PM
my xx is stock and i dont need more power but it still be cool to have some more..... plus in the winter it spend all its time on wot to keep it floatin on 2.5ft of snow
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
post #10 of 22 Old 10-01-2010, 06:36 PM Thread Starter
Lol then u have no back pressure and lose a ton of power.
08 Honda 700xx
Installed
