Brake light won't go off? - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 10-01-2010, 09:05 PM Thread Starter
headscratch Brake light won't go off?
I have noticed lately that my brake light won't go off? It stays on even when the brakes aren't depressed and the headlight is off? When i push the brakes nothing happens? Any idea's on what the cause is? Everything else seems fine?
post #2 of 11 Old 10-01-2010, 09:50 PM
av8r's Avatar
check the rear brake switch. It's the most vulnerable of the 2 switches and yours may be jammed with debris or the bracket could be bent.
av8r is offline
post #3 of 11 Old 10-01-2010, 10:19 PM Thread Starter
ok whats the rear brake switch?
post #4 of 11 Old 10-01-2010, 10:44 PM
The switch that turns the brake light on.
post #5 of 11 Old 10-01-2010, 10:49 PM Thread Starter
Where is it though?
post #6 of 11 Old 10-01-2010, 10:52 PM
Where is it though?
By the brake pedal.
post #7 of 11 Old 10-01-2010, 10:55 PM Thread Starter
Ok so just check it for mud or dirt?
post #8 of 11 Old 10-01-2010, 11:28 PM
That's where I would start.
post #9 of 11 Old 10-01-2010, 11:30 PM Thread Starter
OK thank you sir
post #10 of 11 Old 10-02-2010, 12:34 AM
Take a look at 21-9 and 21-10 in the service manual. If you can't get the light to go off by messing with the right hand lever or the brake pedal, pull the plugs and do a continuity check on both switches. The one thats made up will be your problem. I know the rear one is adjustable, but I have never messed with the one on the front brake.
