Help! Valve cover! - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 10-04-2010, 07:33 PM Thread Starter
Help! Valve cover!
Ok so here is the deal. I am trying to remove valve cover. I got the "T" marked lined up and tops bolts all off. It still feel very tight and do not want to damage anything. Is there something else I have to do? Thanks ahead of time.
chubbycheddarTRX is offline
post #2 of 9 Old 10-04-2010, 07:48 PM
Is it just one cover or both valve covers? You say it feels very tight? What does exactly? Is the top covers just feeling like they are glued on there? Could be sealed really well. If that is the case, you could do a few different things. Try prying it up w/ a screwdriver, being very careful. If that doesn't work, try getting a piece of 2x4 or something to put against the side of the cover and hit it w/ a hammer to slide it off, just gentle taps, nothing crazy.
post #3 of 9 Old 10-04-2010, 08:05 PM
If you are trying to remove the 2 valve covers on the cylinder head, Take all the bolts out and tap "Gently" with a soft hammer. Please don't use a screwdriver.
post #4 of 9 Old 10-04-2010, 08:08 PM
ohhh boy u beat me
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
post #5 of 9 Old 10-04-2010, 08:33 PM Thread Starter
Thanks. it came off. I just didn't want to damage anything. Time to put it back on. The "T" is no longer lined up. When I tried to rotate crankshaft its hard and is sounds like there is air in there. Is that normal?
post #6 of 9 Old 10-04-2010, 08:57 PM
Yes.
post #7 of 9 Old 10-04-2010, 09:13 PM
HAHA. Thanks. I use a big honky one w/ and a slight tap. Guess I shouldn't of wrote pry haha.
post #8 of 9 Old 10-04-2010, 09:27 PM
easy ur startin to sound dirty...
-uni
-primary drive 13t
-pclll
-skyjacker 6'' lift
-sct 100hp tune
post #9 of 9 Old 10-04-2010, 11:14 PM Thread Starter
Got it all back put together. Yeah i've learned to never pry up on certain things. Valves sound is a little louder : (. I did .006 intake and .008 exhaust. Ill check it again tomorrow. Any suggestions?
