Check engine and now she won't run - Club700XX - Honda TRX700XX Forum
post #1 of 37 Old 10-08-2010, 04:42 PM Thread Starter
JUst put the pcv on quad ran great. Then the check engine light came one died and now it won't start stranded at the dunes for 3 more day and no quad!!!
post #2 of 37 Old 10-08-2010, 05:03 PM
boost addict's Avatar
Disconnect the battery for 5 or 10 minutes. Pull your plug and replace(I bet she fouled a plug). Disconnect the pvc and she should fire right up. Get a dyno tune!
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #3 of 37 Old 10-08-2010, 05:14 PM Thread Starter
Yeah I disconnected batter and just up it ba k to stock but nada still have spark but didn't replace
post #4 of 37 Old 10-08-2010, 05:18 PM
Pull the hose to the fuel injector, its at the throtle body(takes 2 small screw drivers) make sure it's getting fuel. Do you hear the fuel pump come on?
Ed @
Chris & Mike
post #5 of 37 Old 10-08-2010, 05:28 PM
Sorry to hear that.
post #6 of 37 Old 10-08-2010, 06:04 PM
mrtheandrew's Avatar
i would still try and replace the plug if youve got a spare. if its a weak spark, it may not be enough. ive run into this problem with lawnmowers- even if the plug is firing when youve got it pulled, it may not be enough oomph when its flooded with fuel and stuff. does it look pretty dirty?
although... i dont think a dirty plug would trip the check engine light. sounds like an issue with fuel.
mrtheandrew is offline
post #7 of 37 Old 10-08-2010, 06:13 PM Thread Starter
Ok has spark has fuel un fuel line pcv has power. I was jumping a bit anyone think of a connection that would come loose and trip edgine light. ??
post #8 of 37 Old 10-08-2010, 06:37 PM Thread Starter
It looked pretty clean and dry. May go buy one tomorrow
post #9 of 37 Old 10-08-2010, 06:42 PM
The fuel tank isn't set to "reserve" or "off", is it?
sgip2000 is offline
post #10 of 37 Old 10-08-2010, 07:38 PM
Sucks man hope you get it running
