oops. - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 10-08-2010, 07:24 PM Thread Starter
sad oops.
So after getting a quote for my oilchange and valve adjustment after break in from my local Honda Shop, I broke down and decided to do it myself. With the manual (downloaded from here THANKS!) and some technical know how, I was able to tear her down in a matter of 1/2 hour or so. The valves were pretty tight, which I heard from local shop is normal. Put her all back together and ran her around the block. All was good untill one of the little spacer/washers for the front fender stay flew off down the road and gone.. =( Also ended up with two extra bolts that I just can not remember where they go.. Went back through everything with no luck. Just two regular 10mm bolts. Pretty short. only other place I saw these style was on the coil pack, however they are too short to be them. Any ideas????
JustMe is offline
post #2 of 11 Old 10-08-2010, 07:27 PM
HHmmm do they hold on the plastic near the tank? That little piece that says TRX700XX?
post #3 of 11 Old 10-08-2010, 07:28 PM Thread Starter
crying
nope....
JustMe is offline
post #4 of 11 Old 10-08-2010, 07:31 PM
hmm?
post #5 of 11 Old 10-08-2010, 08:29 PM
Cranedaddy's Avatar
It'll be alright
Stock 08 TRX700XX
Cranedaddy is offline
post #6 of 11 Old 10-08-2010, 09:30 PM
USMC0861's Avatar
umm on the bottom of the grill the fairing bolts to the grill with two 10mm bolts that are hard to see, and you would really never notice them being gone....check there, right behind the bumper
USMC0861 is offline
post #7 of 11 Old 10-08-2010, 10:13 PM
ranger19jn's Avatar
No that's normal after doing my head on my civic I finished with a whole set of head bolts left over.... Who knew lol jk
Yeah I'd check around the headlight assy and fuel tank
08 trx700xx lot's O mod's
08 ktm 525xc modded
08 yamaha 450 lightly modded
05 grizzly 660SE (sold)
11 rzr s (sold) and missed
sponsors:
Manford Auto Supply (NAPA)
Teixeira Tech:
L8aton Racing:
Fox Racing:
powermadd:
ranger19jn is offline
post #8 of 11 Old 10-09-2010, 07:33 AM
I would def check your plastics. As there seems to be 2 that always nab me, kind of up where the side skirt plastic meets the top, hard to describe.
post #9 of 11 Old 10-09-2010, 09:42 AM Thread Starter
Ya I'm going to yank the tank cover back off they have to go under there somwhere. Being that they aren't allen keys I know thye are probably not visible. Anyway thanks for the help guys. Maybe I'll do the reverse mod today as well.
JustMe is offline
post #10 of 11 Old 10-09-2010, 11:01 AM Thread Starter
Figured out
Found where they went. Tucked way up under front fenders.. Oops. Anyway think im hearing a little to much rattle from the top end, and in true safe than sorry fashion, im going back into the head to double check clearances. =)
JustMe is offline
