Need PC3 map asap - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 10-10-2010, 08:38 AM Thread Starter
Need PC3 map asap
Does anyone have a PC3 map that might work with my set up? (info in signature)
gonna install everything, and i want to be able to ride. no extra cash for tuning.
08 Honda 700xx
Installed
Britalican is offline
post #2 of 6 Old 10-10-2010, 09:02 AM
I have a map that will work for the Big 3. It may be off a tad depending on the exhaust, not sure, but I have given to Scuzz and he had a different exhaust as me and it helped him out. Shoot me a PM w/ your email adress.
post #3 of 6 Old 10-11-2010, 01:10 AM Thread Starter
So I got everything installed today, but I still need a pc3 map. thanks for the map u sent me crwh45, but its way too lean all around. I have to gas the shit out of it just to get it started, and it backfires like crazy when i gas it after that.
Does anyone have a map with a uni filter and a barker full exhaust? I guess the dmc afterburner is a copy cat barker with a few tweaks. thanks.
08 Honda 700xx
Installed
post #4 of 6 Old 10-11-2010, 06:29 AM
Sorry man. I didn't think there would be that much difference with pipes and stuff as far as the programmer goes.
post #5 of 6 Old 10-11-2010, 05:10 PM Thread Starter
yeah me either until i read a bit more about it. looks like i might have to dyno after all.
08 Honda 700xx
Installed
post #6 of 6 Old 10-12-2010, 10:24 AM
Closed Thread
