Fmf program issues - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 10-19-2010, 11:44 AM Thread Starter
Fmf program issues
I just bought a nice used 700xx. Its all stock except for a FMF powercore 4 slip on and a FMF efi programmer. Runs (Ran) good
I wanted alittle more so I took off the air box lid and took out the spark screen in the tail pipe.
I did many test runs and plug checks as I was tuning the EFI till I got a good plug color. It sounded and ran great. I took it for a longer ride and bout after 4-5 miles it started acting up and stalling cutting off. Throttle response went to crap and did have hardly any power.
I thought I tuned it in good but apparently not. Any suggestions what I should go about doing? Would FMF help me out?
Thanks
spdracer71 is offline
post #2 of 7 Old 10-19-2010, 11:49 AM
kinda like this?? https://www.club700xx.com/vb/showthread.php?t=5037
you may be to rich. runs great on short little rides? try going back to the lid and original settings also and see if it does it there on a long ride.
post #3 of 7 Old 10-19-2010, 12:31 PM Thread Starter
yeah very similar although I am ripping around much more aggressive than that dude.
I have had a couple rides with it before I wanted to remove the air lid and it ran great every time.
I am sure that its just not set right. Its crazy they are not a little easier to tune.
THanks for the link
post #4 of 7 Old 10-19-2010, 12:40 PM
yeah i was just doing some passes for a photo shoot and happend to catch it on video. i had mine dyno tuned and they said it fixed it and it was still doing it. i just went to the pcv because i didnt want to mess with it the my ecu shorted out soim down for awhile. try dropping the settings down the programer will still run richer than stock on lowest setting its a guess and check unless u get it dynoed.
post #5 of 7 Old 10-19-2010, 01:06 PM Thread Starter
Yeah now that you mention it I should have been taking it a bit more easy on the test rides in case I really messed something up. I hope I didn't end up hurting anything. Well I guess I have one of 2 things I can do. Either FMF might help me out and get me dialed in OR go back with the air box lid with the original settings. I really don't want to pay to get it dyno'd for that. Thanks a bunch for the insight.
post #6 of 7 Old 10-19-2010, 01:56 PM
sure thing let me know if it works out.
post #7 of 7 Old 10-20-2010, 12:03 PM Thread Starter
I spoke with FMF yesterday they really couldn;t help me out so much. They have Dobeck make there programmers and had me call them for tech support.
The man I talked to said that you really should only tune the Green, Yellow and Red settings. The other settings are kinda more advanced and you can leave them all on the settings that they come from them. (which is Setting 4 for all of them.)
Then he said test each setting green, yellow and red seperate with ridding and go from one extreme the lean till it begins to really act up and go extreme to the rich until it really starts to act up in riding only in each color setting. Then Split the differece in middle on each setting one at a time and your settings will be very close.
Sounds alittle confusing and may take awhile to tune but its a whole lot easier than taking a carb off each time and changing jets.
