pcv and III lcd unit? - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 10-26-2010, 05:12 PM Thread Starter
has anyone used one of these on anything?
http://www.powercommander.com/powerc...ander_lcd.aspx
do you have to hook up other stuff to make the speedo work since our quad dont have one. it looks pretty nice.
post #2 of 3 Old 10-27-2010, 06:47 AM
not sure how it could tell u your speed without gps or wheel sensors. If u want speed and rpm on a hud, u can get a trail tech Vapor. I have one and its fully adjustable to get accurate speed, just dont use the crappy wheel speed sensor mount screw that comes with it. the crew snapped on install, and had to dremel it out and use a better screw. I used my gps to check speed accuracy and its spot on.
08 Honda 700xx
Installed
Britalican is offline
post #3 of 3 Old 10-28-2010, 12:20 PM Thread Starter
yeah i figured u would need some kind of sensor the speedo would be just a nice extra i want it more adjusting the pcv and checking mixtures because i ride from one extream to the other sea leavle to high mt. and it does run different a bit. idk might put it on the christmas list.
