Getting the spark plug out - Club700XX - Honda TRX700XX Forum
post #1 of 19 Old 10-27-2010, 06:49 PM Thread Starter
blk84's Avatar
I just bought an hour meter for my 700xx and I have to wrap it's wire around the spark plug boot. I haven't messed with the spark plug at all since the quad is new, so last night I found it's location on the bike.
I don't know if it's just me but I noticed how inconvienant on where the plug is located. It seems so cramp there with the frame, wire harness, and tank. I have no idea how you would get the boot off or even the plug out. Has anyone else realized this?
Any tips on how to either get the boot out or plug out? It would be a real pain if you had to take some of the plastic off or tank off. Any ideas?
Thanks.
08 700xx aka hillclimber
"If you want something done right, do it yourself"
Dominated...
SW, PA
Wellsville, OH
Buffalo Mtn, WV
Little Coal River, WV
Bearwallow, WV (every blk/red trail)
Rockhouse, WV (every blk/red trail)
Indian Ridge, WV
Pinnacle Creek, WV
blk84 is offline
post #2 of 19 Old 10-27-2010, 07:15 PM
boost addict's Avatar
It hard enough to get the boot off and spark plug out with the tank off. My worst nightmare would be a fouled plug while riding lol.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #3 of 19 Old 10-27-2010, 08:43 PM
The boot is easy to take off without removing anything... I have huge hands, and can do it... I got a little smart, and while I had it stripped, I cut a hole on the plastic under the tank... Now I can change it with a socket and extension without removing pretty much everything!
post #4 of 19 Old 10-27-2010, 08:48 PM
trx tas's Avatar
i have trouble getting mine out
trx tas is offline
post #5 of 19 Old 10-27-2010, 08:59 PM
On mine, the boot comes off hard if it has been on there a while, else it doesn't. It sticks where it goes in the head. Try a little compressed air in the drain hole to loosen her up. If you have the right socket and extension, you can take the tank strap loose on that side and move stuff up enough to get at it.
The hole in the plastic that ceballos did is an excellent idea.
post #6 of 19 Old 10-27-2010, 09:35 PM
I can get mine out relatively easily. The plug comes off easy, and then I just put the socket on it, and then the rachet, lossen it up then pull everything out and get the rest of the plug out by hand.
post #7 of 19 Old 10-27-2010, 10:14 PM
i use socket in the tool kit that came with the xx to take mine out... and i put wd-40 when ever i put the boot back on.. helps a lil
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
post #8 of 19 Old 10-27-2010, 10:31 PM
the boot sticks a bit, but it will pop right off with a little wiggling. the tool kit that came with the bike works fine for me. I have pulled my plug on the trail a few times with no issue.
08 Honda 700xx
Installed
Britalican is offline
post #9 of 19 Old 10-28-2010, 05:39 PM
its easy ive pulled mine in the field a few times with out removing anything. its a little tricky the first time but once you figure it out not bad at all. no real right or wrong way.
post #10 of 19 Old 10-28-2010, 06:10 PM
Please let me know more . I have big hands and on my second plug cap.
Please pm me some pics. I strip the 700xx after every round and this is a pain to me !
