Right side of motor burning hot after drowning the 700xx - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 10-28-2010, 08:23 AM Thread Starter
Hey guys a few months ago I was riding my 700 and I rode through a little puddle wich turned into a 3foot sink the whole quad drowned shut it off right away and got it out after being pulled out by another quad. We tipped it facing up drained all the water out did a good amount of oil flushes now starts right up..now ever since then the whole right side of the motor is burning hot!! I can have 3 layers of pants on and still feel it on my skin..I don't have a clue what it is..first thought was the exhaust so I wrap it up with exhaust wrap and still burns hot..does anybody know or have any ideas what it is???
antmango700xx is offline
post #2 of 6 Old 10-28-2010, 08:28 AM
Hmmm. Anytime I've seen something like that it's because of water left in the oil. But several flushes should've taken care of that, and it's not like water can hide in the oil, it's pretty obvious. I wonder if something could be wrong that's causing a lean condition, or if a bunch of contaminated oil could damage the screen on the oil pickup.
Tom
08 Outlander 800
08 Yamaha Big Bear 400 4x4
OHV Wildcat is offline
post #3 of 6 Old 10-28-2010, 06:17 PM
Me thinkin engine problem. you may have Hydrauliced the motor or dried out the clutch.
post #4 of 6 Old 10-31-2010, 08:07 PM
DblXX's Avatar
Send a message via AIM to DblXX
check and make sure your oil filter is in correctly, gasket facing out.
DblXX is offline
post #5 of 6 Old 11-07-2010, 05:42 AM
Mango where in NJ are you??? I was at a Halloween party and met a guy that had the same thing happen to his quad.
thevinstigator is offline
post #6 of 6 Old 11-15-2010, 10:23 PM
did you change spark plug? i SANK mine big time and rode really easy on way home then did a flush with thicker oil and filter, then changed oil and filter to the good oil and new filter then changed the spark plug and i can't tell a bit of difference now. still strong, no smoke, not any hotter either.
2008 black/grey 700xx. moose nerfs and grab bar, pro armor front bumper, tusk 1 1/8" bars, spider grips, custom indicator light mount, ehs lid & programmer, uni filter,
dwoods90 is offline
