A take on INTAKE/Metal can in filter and Homemade Powerlid - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 10-31-2010, 10:21 AM Thread Starter
Double G's Avatar
Send a message via Yahoo to Double G Send a message via Skype™ to Double G
Just went with a programer, slip-on and Uni. First question is this, Does anyone feel like the metal insert in the filter could be restrictive? I have removed backfire screens on everything so what do you think? I removed this item and used a large washer and bolt to hold the filter in place on another Honda but it was not a 700. Will it suck it inside out??
Also has anyone made their own air box cover out of the outerwear material (found at Micheals) and attached with HD velcro yet. This allows max air flow with protection. I am working on one this week and will post pics. EHS is a great lid but you can do this mod for 12.00!
Double G is offline
post #2 of 6 Old 10-31-2010, 11:35 AM
I have heard that you can just cut the stock filter cage off from the part that goes in the intake tube towards the back of the quad. Also I've seen several guys cut off the snorkel part of the air box lid and just put a pre filter over the top of the opening. The stock cage is restrictive. So those two mods should give you better throttle response.
post #3 of 6 Old 10-31-2010, 01:27 PM Thread Starter
Double G's Avatar
I just removed the metal cage. used grease on the inside of the filter and a bigger clamp to secure to lip on box. I will keep a eye on that and would love the Pro Design aluminum lip I had on my Z400. used the same rear mount using a nut and bolt though the rubber grommet. Really woke the bike up. plus that cage was heavy! GG
Double G is offline
post #4 of 6 Old 10-31-2010, 01:43 PM
boost addict's Avatar
Your Uni filter should have came with a new cage or you purchased just a replacement uni filter. If your using the stock cage, drill 3/8-1/2" holes in it where the tiny holes are, so you have some support for the filter.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #5 of 6 Old 10-31-2010, 02:15 PM Thread Starter
Double G's Avatar
I had a spring that came out of a filter off another quad. I put it inside the filter and it works well. I need to make a correction, the filter I bought was a No Toil and it did not have a cage in it.
Double G is offline
post #6 of 6 Old 11-04-2010, 05:10 PM
me and a few other people have made there own lids with outerwears if you do a search you should find several.
https://www.club700xx.com/vb/showthre...r%2A%2A%2Alids
