Air box cover (stock) - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 11-02-2010, 04:53 PM Thread Starter
I took the cover of my air box off, i was just woundering if its safe to keep it off?
thanks
jaco1234 is offline
post #2 of 11 Old 11-02-2010, 08:37 PM
TRX700XX's Avatar
I never ran mne with out it. it wont hurt it but then you get that loud intake noise and a dirty air box with out much hp gain so there is no point to it if you ask me
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #3 of 11 Old 11-02-2010, 08:51 PM Thread Starter
thanks
jaco1234 is offline
post #4 of 11 Old 11-03-2010, 12:08 AM
2hp gain i can tell it has more power i mostly run with mine off...
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
post #5 of 11 Old 11-03-2010, 11:44 AM Thread Starter
ya i can to and it has alot more "grunt" so i might keep it off but i dont know yet
jaco1234 is offline
post #6 of 11 Old 11-03-2010, 12:36 PM
TRX700XX's Avatar
you can take the piece off the bottom of the lid and it will do almost the same difference
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #7 of 11 Old 11-03-2010, 12:39 PM
I think that any hp gain is marginal. You might not think that your air filter would get dirtier quicker since the air box lid has a wide open scoop anyway... but it does. And a dirty air filter would take away any hp gain. There are other ways to get more air flow... The filter itself... If you look at the cage inside, you'll see how restrictive it is. A UNI filter is not much $$ and flows more air than stock. Or, you can open up the stock cage a bit to allow more air... enlarge as many holes as you can with a drill... But make sure you don't weaken the cage too much.
post #8 of 11 Old 11-04-2010, 12:00 AM
I think I might just cut a hole in the top of the lid and put some panty hose over it, then spray the panty hose with the filter oil.
Anyone have thoughts on that idea before I start cutting? lol
08 Honda 700xx
Installed
Britalican is offline
post #9 of 11 Old 11-04-2010, 05:41 AM
yes why not just buy the EHS lid kit and install it. that way you get more air and filter it 2 birds ones stone
Captamer71 is offline
post #10 of 11 Old 11-04-2010, 05:50 AM
I am going to take measurements of mine today and get a custom outerwears for it so I can have the protection w/ out the cover. I always did this on my 450s.
