Stalling - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 11-03-2010, 04:46 PM Thread Starter
Stalling
Anyone have issues with their 700 stalling out periodically. I seem to notice it happens when i'm pulsing the throttle (not being on or off). I'm used to being able to pop the throttle when i downshift or moving through trails. It seems like the bike does not like my riding style.
I've been riding Honda's since I was 4 and i have multiple motorcycles and a rancher. None of them are this touchy. It seems like my other fuel injected machines are flawless.
Is it just me?
jonohio is offline
post #2 of 10 Old 11-03-2010, 05:25 PM
it the lean stock fuel mix... damn tree huggers.. efi programmer fixes it, same with a 13t
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
post #3 of 10 Old 11-03-2010, 11:05 PM
i noticed that more when i first got it, but it seemed to get better as i broke it in. not sure though.
08 Honda 700xx
Installed
Britalican is offline
post #4 of 10 Old 11-06-2010, 06:01 PM
TRX700XX's Avatar
I had that problem bad but turned out to just be the spark plug was broke on the inside causing the spark to jump to the threads instead of the electrode..... try changing plugs
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #5 of 10 Old 07-04-2011, 11:58 PM
Redline700xx's Avatar
I find stalling a big issue when at idle decending hills. I am expecting my Big 3 kit from EHS any day now. Hope that helps. Is there any way to adjust idle on these bikes?
Redline700xx is offline
post #6 of 10 Old 07-05-2011, 01:18 AM
there is a little screw on the side of the throttle body under a black plastic cover. adjust it in to open the throttle a little (may want to use lock tight to hold in position) , and make sure to adjust the throttle cable tension accordingly. doing this may void the warranty on this part as Honda manual says not to adjust the screw.
08 Honda 700xx
Installed
post #7 of 10 Old 07-05-2011, 07:17 AM
This issue has been brought up almost everytime I talk with other 700xx riders. My xx, my brothers, and my buddies all do it sometime. It's just something to get used to. The 13t sprocket does help some I believe. I hope a future purchase of an EHS package helps as well.
2008 Black/Grey TRX700XX:
EHS Airbox & Uni Filter
13t Front Sprocket
Motoworks Exhaust System
PRM Bumper
Quad Boss Rack
Ds450 Shocks
L8ton Sway Bar
Stabilizer
MotionPro Twist Throttle
Pro Armor Nerfs
Winch Installed
Reverse Rev Limit Uninstalled
"Trust in the LORD with all your heart and lean not on your own understanding; in all thy ways acknowledge Him and He shall direct thy paths." Proverbs 3:5-6
Black&Blue7XX is offline
post #8 of 10 Old 07-06-2011, 03:43 PM
I guess pulsing the throttle is the same a blipping the throttle. The xx tends not to like this. A learning curve for me also as for doing the same on descent of hills etc , check you have not got too much play in the clutch cable.
I had problems with stalling early one when I first bought. Most of it was just adapting to the xx from a 450r.
post #9 of 10 Old 07-06-2011, 06:07 PM
92K1500's Avatar
When was the last time you cleaned your air filter?
2008 Honda TRX700XX
AC Racing MX Nerf Bars.
PRM Desert Grab Bar.
92K1500 is offline
post #10 of 10 Old 07-08-2011, 03:02 PM
I have yet to experience staling on a down hill decent. Usually I shift into neutral and cost down hill, and sometimes even shut to quad off. Some of the down hills I run in WV. Go from 1400ft. to 800ft. so you are coasting sometimes over 5 minutes, and still reaching speeds of 25- 30 mphs.
