how to change your air filter - Club700XX - Honda TRX700XX Forum
post #1 of 13 Old 11-06-2010, 10:35 PM Thread Starter
Question how to change your air filter
i was wondering how to vhange my air filter
uni air filter
just ride
hondatrx700xx is offline
post #2 of 13 Old 11-06-2010, 10:48 PM
Loosen up the clamp, take off the bolt and bracket from the back, and slide filter off. Replace with a UNI...
post #3 of 13 Old 11-06-2010, 10:57 PM Thread Starter
i dont want to break anything so how dose the braket come off
uni air filter
just ride
post #4 of 13 Old 11-06-2010, 10:58 PM Thread Starter
the uni is on the way and do u no how much more hp the filter gives u
uni air filter
just ride
post #5 of 13 Old 11-06-2010, 11:54 PM
maybe 1hp? the bolt on the back of the filter/bracket is a biatch to get off! I had to dremel mine off and replace with a bolt from lowes! Good luck!
post #6 of 13 Old 11-07-2010, 12:06 AM
Screwdriver????... its just a phillips screw holding that bracket
post #7 of 13 Old 11-07-2010, 12:29 AM
Rith's Avatar
You just take your seat off, pop the plastic lid off in the back (Held on by 4 little latch brackets you just pop off by hand). You will see your filter, take a screw driver and take off the back piece. Its a pain in the ass..
Then unscrew the filters bracket and it just slides out. Don't forget to oil it (thin coat sprayed on generally)
EDIT: I'm about the least mechanically oriented guy in the world and this things a breeze to work on. There are many guides here for many things (such as oil changes etc...): https://www.club700xx.com/vb/forumdisplay.php?f=23
Rith is offline
post #8 of 13 Old 11-07-2010, 02:56 AM
wait till u gota adjust ur valves...
the chang ur air filter u gota
1. take ur seat off
2.yemove the air box cover (4 meatal clips hold it down)
3. get a #2 (i think) screw driver and remove the clip the suports the back of the air filter...
4. get a #1 screw driver and lossen the band clap arond the front of the air filter.
5. remove air filter..
note: if u got a uni spray wd-40 arond the inner lip so it slides on easly.... and dont forget to oil it.....
a uni probaly will give u 1 hp o the topend ... just by keepin ur air box lid off ull get 2hp with stock filter...
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
post #9 of 13 Old 11-07-2010, 08:24 AM
If you do manage to get the screw out on the back of the "L" bracket (back of the filter) I'd take it to your local hardware store and get one that has a HEX head, so you can just use an Allen wrench to get it out. It seems like Honda put Loc-Tite on that lil sucker which makes it difficult to get out. Also, I am assuming this is one of your first times changing the filter (sorry if I assume incorrectly), but while changing it you should clean your air box. Be sure to put a rag or something in your intake to be sure no dust or anything gets in there, and you can wipe your intake out as well, sometimes dirt and dust gets up in there.
post #10 of 13 Old 11-07-2010, 10:01 AM Thread Starter
yea this is my first time so i figured that all of you have done it once or twice thanks for the help everyone
uni air filter
just ride
