For the more educated. - Club700XX - Honda TRX700XX Forum
post #1 of 14 Old 11-08-2010, 01:10 PM Thread Starter
TRX700XX's Avatar
Let me see if i can make any sense of this...... ok bigger front sprocket is for top speed and smaller rear is for top speed...i know that.... the question is 1 tooth larger in the front is equal to how many teeth smaller in the rear? anyone got a clue?
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #2 of 14 Old 11-08-2010, 01:18 PM
skier207's Avatar
Roughly 3
skier207 is offline
post #3 of 14 Old 11-08-2010, 01:20 PM
+1 around 3
2006 Raptor 700
post #4 of 14 Old 11-08-2010, 01:24 PM Thread Starter
TRX700XX's Avatar
ok because i was not sure about going to a 15 front so maybe i will consider a 35 rear instead or something......thanks
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #5 of 14 Old 11-08-2010, 01:39 PM
I would try the 15 in front first for a few reasons. 1) will be cheaper 2) easier to get at and change 3) more accessible parts wise.
http://www.sprocketcenter.com/g/4156...tio-chart.html
http://gearingcommander.com/
A couple sites so you can compare what different sprockets will do.
post #6 of 14 Old 11-08-2010, 01:59 PM
less than 3 i usually figure 2.5 but 3 is close its
14-37=
37/14 = 2.64 ratio
15-37
37/15 = 2.46 ratio
14-34
34/14= 2.42 ratio
14-34.5 (if you could do a 1/2 tooth)
34.5/14 = 2.46 ratio
EHSRACING is offline
post #7 of 14 Old 11-08-2010, 02:24 PM
Now you need to tell us how to 1/2 tooth. Just being a smart ass... again.
post #8 of 14 Old 11-08-2010, 03:40 PM
you dont have any of the half tooth sprockets? thats what your supposed to use with the half link master links
post #9 of 14 Old 11-08-2010, 04:20 PM Thread Starter
TRX700XX's Avatar
I thought every one ran half links and sprockets?? lol But thanks i never thought of putting it in to ratios that makes a lot more since to me now!
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #10 of 14 Old 11-08-2010, 06:00 PM
I had an excel sheet for this, let me know if you are interested and I can e-mail it to you. It is really just rT/fT with all the different combinations if you want to make your own.
