pcv problems - Club700XX - Honda TRX700XX Forum
post #1 of 16 Old 11-08-2010, 02:52 PM Thread Starter
boost addict's Avatar
pcv problems
Ok recieved the pcv and hook it up to the injector, and spliced the yellow wire with blue stripe on the tb for the tps. Loaded a base map into the pcv and the quad will run for 2 seconds and die.
Any ideas? Did you have to zero out the tps sensor?
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #2 of 16 Old 11-08-2010, 03:11 PM
Have you tried calibrating the TPS? You do this by clicking on "calibrate" then quickly push the thumb throttle to WOT and back and click on "ok". Also, do you see any lights on the PC5?
2006 Raptor 700
post #3 of 16 Old 11-08-2010, 03:41 PM Thread Starter
Green light is on. I will load the software on my laptop and then try calibrate the tps. I loaded it on my home pc like a dummy. I also did not think it was necessary, but have been wrong 100 times before.
Ed @
Chris & Mike
post #4 of 16 Old 11-08-2010, 03:44 PM
Also make sure you have the latest Power Commander software on your computer and maybe update the PC5 firmware while you are at it?
2006 Raptor 700
post #5 of 16 Old 11-08-2010, 04:28 PM Thread Starter
All updates have been complete. I follow directions and calibrated with the enginge off, click reset open throttle 100% and close, clicked ok. Software led reads throttle @100% at idle?
Ed @
Chris & Mike
post #6 of 16 Old 11-08-2010, 04:41 PM
Mine did this yesterday when I recalibrated so I actually calibrated with the engine running. I mean if it stays running.
2006 Raptor 700
post #7 of 16 Old 11-08-2010, 04:46 PM
Another quick question because I don't know how it is setup on the xx but: Any way you can get the plugs mixed up? I mean on my rappy you can get the injector pug and the TPS plugged mixed and the PC5 does not work.
2006 Raptor 700
post #8 of 16 Old 11-08-2010, 05:15 PM Thread Starter
I called pc and they took remote access of the laptop. He had this thing purring in 5 minutes. The tps values were off, the stock voltage at 100% throttle is 4.4 volts, if it helps anybody in the furture. Map# M16-004-005 is the map i am using as a base tune, before the dyno tune.
Ed @
Chris & Mike
post #9 of 16 Old 11-08-2010, 05:17 PM Thread Starter
Thanks Rappy for your help! He reset the tps while the quad was runnung. The directions say to do it with the bike off lol.
Ed @
Chris & Mike
post #10 of 16 Old 11-08-2010, 11:10 PM
Yeah, I do it running like I said too. Glad you have it up and running! You're welcome for the help.
2006 Raptor 700
