Idle adjustment - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 11-09-2010, 06:07 PM Thread Starter
TRX700XX's Avatar
Idle adjustment
Did anyone figure out if an idle adjustment exist on the trex?
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #2 of 12 Old 11-09-2010, 06:13 PM
boost addict's Avatar
There is no idle adjustment, they use a tps. Idle is set to 1500-1600rpm at 0% throttle in the ecm.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #3 of 12 Old 11-09-2010, 06:18 PM Thread Starter
TRX700XX's Avatar
figured but it was worth a shot to ask just in case i looked over it...thanks
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #4 of 12 Old 11-11-2010, 03:53 PM
Try this !
https://www.club700xx.com/vb/showthre...ustment&page=3
post #5 of 12 Old 11-11-2010, 05:02 PM
The engine ecm is designed to idle at 1500rpm . If your is not, you have a other problems lol. Section 6-58 in the service manual. Download link here.
http://www.megaupload.com/?d=IUS0E3HT
Ed @
Chris & Mike
post #6 of 12 Old 11-12-2010, 11:23 AM
there is an idle adjustment its next to the pipe on the TB the ecu doesnt control idle its just a cpu that controls fuel delivery for what you tell it if you set your idle to 5000rpm and tell your ecu that 0% is there with the tps it thinks thats idle, might not work very well but you control idle
EHSRACING is offline
post #7 of 12 Old 11-12-2010, 04:36 PM Thread Starter
TRX700XX's Avatar
I am glad ya'll mentioned valves cause i checked mine from curiosity and found out that my local dealer that just did mine wayyyy over tighted one exhuast valve! So the problem was that and not the idle like previously intended. So i ended up fixing their mistake!
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #8 of 12 Old 11-12-2010, 08:09 PM
scrawny's Avatar
how do you search that site? thanks for the manual!!!
08 700xx
05 Ruckus
04 450r
86 Fat Cat
86 350x
81 250r
72 CB100
scrawny is offline
post #9 of 12 Old 11-12-2010, 08:26 PM
skier207's Avatar
The notion that the ECU doesn't control Idle on this machine is incorrect. The thottle body has a IACV (idle air control valve) that is controled by the ECU.
skier207 is offline
post #10 of 12 Old 11-12-2010, 08:51 PM
The electric control module(ecm) reads input voltage and values of the sensors(iacv one of many Section 6-15) and uses it's input voltage and values to control the efi system of the 700xx. Section 6-56 in the service manual.
Ed @
Chris & Mike
