drive chain adjustment - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 11-15-2010, 03:12 PM Thread Starter
ok im kinda newer to race quads so i wanna make sure i do everything at the right times and don't make a ignorant mistake and mess something big up. i always check to make sure the chain isnt too loose but in the book it gives how loose it is when it needs to be tightened. isnt it pretty straight forward to tighten it? loosen bolt, slide back then tighten?
thanks for the help and any other advice is super
2008 black/grey 700xx. moose nerfs and grab bar, pro armor front bumper, tusk 1 1/8" bars, spider grips, custom indicator light mount, ehs lid & programmer, uni filter,
dwoods90 is offline
post #2 of 3 Old 11-15-2010, 03:27 PM
It's extremely easy to adjust. You need something like a 17mm wrench on one side and a 24mm on the other, if memory serves (or a 12" crescent wrench if you're like most of us). Loosen the main through bolt with these wrenches, then turn the labeled cams to get your tension right. Then tighten. That will make more sense when you're looking at it, but the instructions in the owner's manual are pretty decent, if I remember correctly.
Tom
08 Outlander 800
08 Yamaha Big Bear 400 4x4
OHV Wildcat is offline
post #3 of 3 Old 11-15-2010, 05:38 PM
Watch for wear marks on youre front sprocket. On the sides of the teeth. This will tell you if you aligned properly.Only seems I have had this problem.
