Dash lights all on!!??? - Club700XX - Honda TRX700XX Forum
post #1 of 21 Old 11-15-2010, 09:35 PM Thread Starter
J-Farm's Avatar
pissed Dash lights all on!!???
I had a problem not long after i baught my quad and it was putting all the dash light on except for neutral; and it would do at a certain rpm in any gear.. so i got rid of the reverse limiter and it fixed it.. but now it's doing it again in a high rpm instead now, i have no clue whats goin on so i'm gonna call honda tomarrow.. but if anyone has any suggestions, let me know!
1986 ATC250SX
2008 TRX700XX red
Reverse limiter removed; Shaved front fenders; Custom 2" receiver hitch; 10" ITP T-9 pro series rims all the way around; 23" razrs up front; 22x12x10 Kenda Bear Claws in the rear
J-Farm is offline
post #2 of 21 Old 11-16-2010, 09:06 AM
AusTrx700xx's Avatar
just a guess, but i would say u have a wiring short, and the vibration from the rpm and causing the wires to short, as far as the removing the rev limiter fixing it i would say this caused the wires to move and come away form each other so they cant short, and over time they have moved back,
like a say its just a guess but if you have the quad running and move the wires, especially near the ecu by the sounds of it, and see if the lights come on
AusTrx700xx is offline
post #3 of 21 Old 11-16-2010, 09:08 AM
also check your batt treminals are tight caus a loose terminal could cause it to loose power (voltage) for a sec then come back on causing the lights to come on just like when you turn the key
post #4 of 21 Old 11-16-2010, 12:13 PM
it says u removed your reverse limiter so i would go and check all the wires you cut. also honda may not warrenty/fix it since you cut the wires. hopefully its not the case.
post #5 of 21 Old 11-16-2010, 09:28 PM
Does anybody have a wiring diagram that is legible? I can't read the one on the scanned owner's manual.
post #6 of 21 Old 11-17-2010, 06:19 AM
Aust700 I also remember reading that standing up a 700xx is not a good idea unless some oil lines are pinched. Saw your profile pic so you might want to look into that as well.
chubbycheddarTRX is offline
post #7 of 21 Old 11-17-2010, 07:19 AM
i dont stand my 700 up like that on purpose
that was by mistake. i accedently gave it a bit too much gas on my new ramps (which have teeth in them) while loading it up, which resulted in that pic u see, and me flat on my back behind the ute laughing my arse off,
post #8 of 21 Old 11-17-2010, 10:24 AM Thread Starter
J-Farm's Avatar
it was the battery, i forgot to tighten them up last time
1986 ATC250SX
2008 TRX700XX red
J-Farm is offline
post #9 of 21 Old 11-17-2010, 10:34 AM
Rith's Avatar
Ha thats great
And nice to hear you got it fixed j-farm
08' TRX700xx - Red n' Black
Big Gun EVO r Exhaust
00' CR250rintintin
Rith is offline
post #10 of 21 Old 11-17-2010, 10:43 AM
I'm glad that was it. My Can-Am was going crazy one time, only responding to throttle inputs half the time, idling like crap. It terrified me. It took me awhile to figure out that I had the same problem, i was trying to load the thing up to take to the dealer when I finally found it. My friends crucified me when I had the big fancy quad that wouldn't run, but it would've been much worse if I had taken it to the dealer for a loose battery cable, so I was lucky.
Tom
08 Outlander 800
08 Yamaha Big Bear 400 4x4
OHV Wildcat is offline
