can you bore a stoc 700xx jug? - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 11-16-2010, 10:59 AM Thread Starter
Simplyorange's Avatar
after sinking my bike, we have determined that the clanking noise is the piston walking in the cylinder due to the ring being washed away. my question is, can i bore the cylinder to an oversized piston like i have done to other bikes because i was told it may be chrome lined and has to be replaced. im asking because i cannot find any oversized pistons,all of them are standard bore high compression.and if i can bore it i want to find out what dimensions i need to bore it to to accept a piston.
2007 GSXR 1000 (Orange/Black)
Simplyorange is offline
post #2 of 6 Old 11-16-2010, 11:20 AM
09RappySE's Avatar
Quoted: 16 Post(s)
Yes you can bore your cylinder, your cylinder is nikasil coated, and it can be re-coated after bore, I would call CP pistons and inquire about a custom piston if there are none out there.....you could probably use a raptor piston and machine the valve reliefs if needed. Bo would know.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
post #3 of 6 Old 11-16-2010, 11:30 AM Thread Starter
they say at honda that it is not nickel coated and can be bored .25 over, for $278 i can buy a new cylinder, and i can find new pistons in the stock bore size much easier. are you positive it is nickel coated?
post #4 of 6 Old 11-16-2010, 01:14 PM
Thumper Racing makes a big bore kit:
http://thumperracing.net/index.php?r...&product_id=91
They do not mention that the cylinder needs to be replated after boring, so that makes me think it is not plated. Does the stock cylinder have a steel sleeve? Its bore can't be all aluminum, the aluminum won't hold up without being plated. I have not had my engine apart yet to know, but I would think someone on here has and should be able to give you the correct answer.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #5 of 6 Old 11-16-2010, 01:49 PM Thread Starter
im not looking for big bore, im looking to get rid of scarring if there are any, but i just had a buddy of mine bet money that my piston is fine and that my clutch basket beraing is bad, makes since because i found out honda did a bearing revision recently.
post #6 of 6 Old 11-16-2010, 02:39 PM
Well, you have to bore the cylinder no matter what. If you are going to buy a new piston and bore the cylinder, might as well go big bore and pick up some more power. Regardless if you bore it 3 mm or .25 mm, it is going to cost you close to the same when all is said and done. If I have to spend money, I would rather spend it knowing I will pick up a little power then just replace with stock parts. Just my opinion.
I do agree with your buddy though, I don't think it is your piston clanking.
Doug
2005 TRX450R
1986 TRX250R
