Clutch Adjustment and Noise - Club700XX - Honda TRX700XX Forum
post #1 of 23 Old 11-22-2010, 10:28 PM Thread Starter
Is there any adjust you can make to the clutch other than at the handlebars? Sometimes I have to pull the clutch in and out when down shifting to get it back in first gear. Sometimes when shifting from first to reverse i have to ease the clutch out to let it slide into reverse. While idling there is also alot of noise coming from behind the clutch cover. Has anyone experienced this?
post #2 of 23 Old 11-22-2010, 10:56 PM
Yes, you can adjust on the left side of the engine where the linkage goes into the case. Having to mess with the clutch for non moving gear changes is pretty normal. What kind of noises are you hearing? Just a chunking gear noise when it finally goes in?
post #3 of 23 Old 11-22-2010, 11:05 PM
Rith's Avatar
I don't know about the rest of your post, but you should have to let the clutch out just a bit for reverse to engage. Not all the way just a tad normally
08' TRX700xx - Red n' Black
Big Gun EVO r Exhaust
00' CR250rintintin
Rith is offline
post #4 of 23 Old 11-23-2010, 09:32 AM
Blak92's Avatar
Normal to have to let the clutch out a tad, especially when sitting still.
Blak92 is offline
post #5 of 23 Old 11-23-2010, 12:33 PM Thread Starter
Its like a chunking noise when in nuetral while its idling with the clutch let out.
post #6 of 23 Old 11-23-2010, 12:50 PM
Hum...............does it change when you pull the clutch in?
post #7 of 23 Old 11-23-2010, 02:24 PM Thread Starter
yeah it does when you pull the clutch in it is quiet and doesnt make the noise im wondering if it could be the cluth basket bearing. The bike doesnt have but around a hundred miles on it. It just seems abnormally loud to me.
post #8 of 23 Old 11-23-2010, 03:11 PM
Simplyorange's Avatar
fix it now, i just had to change my discs, basket and bearing, still dont know why, the clutch felt fine on it, and never had an issue, it suddenly all went out and started making a knocking noise.
2007 GSXR 1000 (Orange/Black)
Simplyorange is offline
post #9 of 23 Old 11-23-2010, 04:30 PM Thread Starter
well the clutch still feels good its just making a knocking noise when in nuetral ill check it out this week or next week and see what the problem is
post #10 of 23 Old 11-23-2010, 05:16 PM
The chattering noise from what I have done and another post is the bearing in the center of the basket is a loose fit from new. I believe (from another post) that there is an updated bearing that is a better fit.
I'll try and find the post and check else where to verify this.
