Won't Start!!!! - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 11-25-2010, 02:53 PM Thread Starter
Won't Start!!!!
I'm going insane here trying to figure out why it won't start!.. I have gas, battery is good. Went through 3 new plugs thinking that might be it. I adjusted my valves but don't know if that's why it won't start... hmmm... any ideas????
post #2 of 7 Old 11-25-2010, 04:48 PM
first thought the roll over sensor maybe , Have you checked for a spark ?
post #3 of 7 Old 11-25-2010, 04:55 PM
USMC0861's Avatar
I'm not being an ass here....kill switch? Engine stop switch? Starter solinoid?
Spray a bit of starter fluid down the TB....does it sputter, easy way to narrow down a fuel/elec problem....?
USMC0861 is offline
post #4 of 7 Old 11-25-2010, 04:57 PM
USMC0861's Avatar
And if you just did your valves....check the compression with a compression tester...if it is significantly lower your valve may be cracked open....just a few Ideas
USMC0861 is offline
post #5 of 7 Old 11-25-2010, 05:07 PM
I would check for spark first, if you took the plug cap off to adjust the valves it may have come loose at the coil.
post #6 of 7 Old 11-25-2010, 05:17 PM
boost addict's Avatar
Do you hear the fuel pump come on?
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #7 of 7 Old 11-25-2010, 06:25 PM Thread Starter
back in action!!!!.... thanks for trying to help guys... i got sooooo frustrated, that I stripped the quad down all over again... checked for spark and was good! fuel pump would come on... so i follow every possible wire from the plug, to the starter, and in between... it turns out, somewhere in the mix of everything, the 2 wires that plug into the ignition coil came loose...
on a good note, i'm getting really good at stripping the quad down and putting it back together pretty fast!
