105mm? - Club700XX - Honda TRX700XX Forum
post #1 of 27 Old 11-29-2010, 05:51 PM Thread Starter
105mm?
I'm new to the site, and I have a 400ex that I stuffed an xr650r into. The stock bore is 100mm, and I can get a 102.5mm kit that puts it at 680. Since the top ends are so similar to the xx, I bought a 700 cylinder, to start off at 686. The only mod I have to do to get the cylinder to work for me, is put an "aluminum gasket" of sorts, to space the cylinder upwards a bit. I already have those measurements, and I'm getting ready to mock it up on my spare motor. Since I already have a 680 xr jug, I want the xx to be bored out to a 105mm. I've only seen a few kits, but haven't found any good info on whether or not the stock sleeve can handle a 105. I'm going to use the xr head, and the xr rod and bottom end. Finding a 105 piston for the xr shouldn't be an issue, I am just trying to find out whether I need to resleeve or not.
tayyo789 is offline
post #2 of 27 Old 11-29-2010, 06:10 PM
I have not a clue. But good luck in your awesome endeavor!
Tom
08 Outlander 800
08 Yamaha Big Bear 400 4x4
OHV Wildcat is offline
post #3 of 27 Old 11-29-2010, 06:15 PM
I am curious about this setup , as I thought the coolant passages where slightly differant at the front of the cylinder ?
Do they meet up on the front dowl ?
I am only going off pics and would like to know.
post #4 of 27 Old 11-29-2010, 09:08 PM Thread Starter
There are little differences, but when they are together, it will still work fine. The biggest difference between the two cylinders, besides the size of course, is the weight. Just by holding them side by side I would have to guess that the xx jug weighs at least twice as much as the xr's. The xr doesn't have a steel sleeve though, it is nikasil coated.
tayyo789 is offline
post #5 of 27 Old 11-29-2010, 09:21 PM
OK , Do the base gaskets match !
post #6 of 27 Old 11-30-2010, 04:21 AM Thread Starter
I don't have any that are for the xx yet, so I don't have that answer. Being away from home for school slows down my bike building a lot. I'll know in about a week when I get it all together
tayyo789 is offline
post #7 of 27 Old 11-30-2010, 04:51 AM
Call alba directly and ask, they are grat guys and have this answer. I can't remember off the top of my head but i did ask this question to them when i dropped my bike off a couple months ago and they had a answer.
UpOnGaMe is offline
post #8 of 27 Old 11-30-2010, 06:29 AM
VelociRaptor's Avatar
The stock sleeve in the XX cylinder will go 105mm but I wouldnt trust it. I would send it off to White Knuckle for thier resleeve job and reinforcement of the top of the cylinder.
Bo White
205-886-7043
VelociRaptor is offline
post #9 of 27 Old 11-30-2010, 03:34 PM Thread Starter
I saw what White Knuckle does, but I'm wondering how neccesary the reinforcing really is. If I could get away with just a resleeve, without the reinforcements I can get it done at a wayyyy better price than what they want for it.
And I'm also wondering about the Alba port job on the xr head. I've seen your thread Bo, and it looks very nice, but a little pricey. I can imagine they aren't doing the things you did on that XXX portjob, but a comparison would be nice from someone who actually had Alba do it.
tayyo789 is offline
post #10 of 27 Old 11-30-2010, 05:29 PM
I do a +1 port on the XX cylinder head. I just throw XR intake valves in and port the cylinder head accordingly.
I just honed a reinforced cylinder, it moved around .0005" while I was honing, dont want to know how much one thats not reinforced moves around.....
Bo White
205-886-7043
