Modquad with K&N Filter - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 11-29-2010, 11:29 PM Thread Starter
Just got the Modquad filter kit with K&N filter and what little installation instructions came with it seem very confusing. I'm not around my bike so I haven't had a chance to try an install
Does anyone have this setup and have photos of the install process and what it is supposed to look like put together?
From what I get from the instructions, the filter should clamp onto the air flow tube, but a quick test fit makes this seem impossible. The filter openning is about 1.5 to 2 inches bigger than the tube.
thegreek66 is offline
post #2 of 6 Old 11-30-2010, 12:16 AM
92K1500's Avatar
The Modquad kit should come with a metal ring, a clamp and your filter.
Slip the metal ring into the rubber hose leading into your airbox, put the clamp on it, then slip your air filter onto the ring and put the clamp on it.
Doesn't take very long to do at all.
2008 Honda TRX700XX
AC Racing MX Nerf Bars.
PRM Desert Grab Bar.
92K1500 is offline
post #3 of 6 Old 11-30-2010, 06:02 AM Thread Starter
I kinda figured it was that easy. Only thing is the filter openning seems way to big for the ring that came with the kit. Probably a 1.5 to 2 inch diameter difference.
post #4 of 6 Old 11-30-2010, 06:46 AM
92K1500's Avatar
There shouldn't be that big of a difference unless they sent the wrong ring.
2008 Honda TRX700XX
92K1500 is offline
post #5 of 6 Old 11-30-2010, 06:55 AM Thread Starter
That's what I was thinking, or maybe the wrong filter.
post #6 of 6 Old 11-30-2010, 09:04 AM
92K1500's Avatar
I don't think many filters are bigger than what fits the xx.
2008 Honda TRX700XX
92K1500 is offline
