Correct Spark Plug Gap - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 11-30-2010, 02:35 PM Thread Starter
Double G's Avatar
Send a message via Yahoo to Double G Send a message via Skype™ to Double G
I fouled my first plug tuning with the Dobeck programer, slip-on & airbox lid off. guess I was to rich. Wanted to do some plug runs anyway but I need to know the correct spark plug gap, I can't find it and am in a hurry. Thanks. I downloaded the Service Manual but cant find the owners manual, any links out there? GG Great forum guys.
Double G is offline
post #2 of 8 Old 11-30-2010, 03:26 PM
most plugs will come correct or close enough to not worry about at least ngk. The denso plugs im not sure i havent used those much i know i saw a couple failures with them.
run somewheres around .030-.032 on bigger builds that run at a higher rpm you can close them up some and it will help with blow out also alcohol and some other fuels i have tested will like different gaps but on normal stuff with normal fuels those numbers should do you well i think denso follows the same gap as ngk but im not 100% positive
EHSRACING is offline
post #3 of 8 Old 11-30-2010, 07:45 PM
http://www.ngksparkplugs.com/part_fi...?id=736&type=v
chubbycheddarTRX is offline
post #4 of 8 Old 12-01-2010, 10:46 AM
i dont know what link you have but .044 is a big gap for the ignition systems on most atv's
post #5 of 8 Old 12-01-2010, 10:49 AM
in my opinion
post #6 of 8 Old 12-01-2010, 11:05 AM
I went of the NGK website. Thats what they say is correct, so to be honest I'm not exactly sure either.
post #7 of 8 Old 12-01-2010, 08:56 PM
droby1242's Avatar
.039-.043 is what the manual says but i agree that is a little high. thats pg 1-11 out of the honda maintenance manual though. you can download the manual from our how to section for free.
droby1242 is offline
post #8 of 8 Old 12-01-2010, 09:10 PM
Its on your front right frame tube,top shock mount to bumper .1.0 to 1.1 mm.
