High idle - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 12-01-2010, 01:53 PM Thread Starter
TRX_Sixpac_700xx's Avatar
High idle
I went and started up my quad yesterday after sitting for a couple weeks. It started up and went to move the truck out of the way and the whole time I noticed that it sounded abnormally loud. When I went back to the quad I noticed that the idle seemed very high. I pumped the throttle once and could definitely tell that the idle was definitely high and I turned the quad off.
I checked a few things around on the quad and made sure my fuel programmer was working, which it seemed to be. I went to restart the quad and it popped and I let off.
After checking things over again and giving it a couple of minutes I started the quad back up and within seconds the header was glowing bright orange, which it was dark and this isn't an abnormal occurrence, but I don't think that it had ran long enough for it to be bright orange already.
I didn't get any stabil in my gas and I am wondering if my gas is old since I have had it for a couple of months. My other thoughts are maybe the fuel filter is just plugged or the freezing temperatures are causing problems with my EFI controller (juicebox). I am really hoping that I don't have bad fuel through my system, but it is definitely a possibility.
Does anyone have any thoughts on this?
TRX700XX
-UNI Air Filter
-2Bros Exhaust
-2 Bros Juice Box
-13T Sprocket
-Pro Armor Fat Pegs (Black)
TRX_Sixpac_700xx is offline
post #2 of 3 Old 12-01-2010, 04:05 PM
unplug ur fuel controler see what happens
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
post #3 of 3 Old 12-01-2010, 04:47 PM
check for an air leak or binding in your throttle cable
EHSRACING is offline
