H.I.D lights - Club700XX - Honda TRX700XX Forum
post #1 of 19 Old 12-08-2010, 06:31 PM Thread Starter
TRX700XX's Avatar
H.I.D lights
Where are ya'll getting you HID kits from?
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #2 of 19 Old 12-08-2010, 07:06 PM
TRX700XX,
I'm glad you brought up this subject. I've thought about one of those lights for my machine but I don't know whether the electrical system on the XX will support the current requirements along with the regular lighting system. Hopefully someone on this forum has some experience in this area.
post #3 of 19 Old 12-08-2010, 07:45 PM
HosRacn's Avatar
hid lights pull less amps than reg lights!!! Stock stator is like 225 or 250 watts!! I run 2- 4" hid's and stock light, Matlock runs 2- 8" hid's and stock!!
Jeff Hoskins 72K
Brawley Radiator & Glass, Sand Posse, Imperial Valley Cycle Center, Scott Goggles, PowerMadd, CP Pistons, Graffik Graffiti, OMF, GoPro, Elka, Houser Racing, Fly Racing, Big Gun Exhaust and Renthal.
HosRacn is offline
post #4 of 19 Old 12-08-2010, 08:18 PM
92K1500's Avatar
HID's use 35w each to run (unless you get the 55w kit, but those will probably melt our headlight housings). Startup will draw more, but that's what the battery is for.
And DDM makes decent stuff and is cheap.
2008 Honda TRX700XX
AC Racing MX Nerf Bars.
PRM Desert Grab Bar.
92K1500 is offline
post #5 of 19 Old 12-08-2010, 08:22 PM
92K1500's Avatar
http://www.ddmtuning.com/products/101/
Our bulbs are H6M and I'd suggest 4500k, 5000k or 6000k.
2008 Honda TRX700XX
92K1500 is offline
post #6 of 19 Old 12-08-2010, 08:57 PM
HosRacn's Avatar
What bulb does the polaris Razr-s take?
Jeff Hoskins 72K
HosRacn is offline
post #7 of 19 Old 12-08-2010, 09:27 PM
92K1500's Avatar
The 2011 model takes a H13. I'm still seeing if the 09-10's use the same.
2008 Honda TRX700XX
92K1500 is offline
post #8 of 19 Old 12-08-2010, 09:30 PM
92K1500's Avatar
Okay, looks like the older ones use the 880 bulb size.
2008 Honda TRX700XX
92K1500 is offline
post #9 of 19 Old 12-08-2010, 10:05 PM
HosRacn's Avatar
ok cool thanks will have to order some!! Might order some for my 700 also, I have both hi/low wired together helps alot!!
Jeff Hoskins 72K
HosRacn is offline
post #10 of 19 Old 12-09-2010, 02:43 AM
skier207's Avatar
Here is a really good write up on how to install HID's and link to buying them from the write up, seems the price has come down.
https://club700xx.com/vb/showthread.php?t=817
http://cgi.ebay.com/ebaymotors/ws/eB...m=260370986777
skier207 is offline
