Race fuel questions - Club700XX - Honda TRX700XX Forum
post #1 of 16 Old 12-12-2010, 11:21 PM Thread Starter
08700xx's Avatar
Race fuel questions
I am going to be running 12:1 on my XX and need to get some race fuel. My questions are what fuel would you recommend (I'm thinking VP but they have way to many options and I don't know much about race fuel) and do you know of any place I can order fuel online or where I can find it around Orange County CA?
08700xx is offline
post #2 of 16 Old 12-13-2010, 01:41 PM
TRX700XXX's Avatar
I think VP U4.4 and VP C12 are the popular ones to run. The U4.4 is oxygenated while the C12 is not.
TRX700XXX is offline
post #3 of 16 Old 12-13-2010, 01:44 PM
Try the link below for race fuels "at the pump"
http://www.davebarton.com/Unleaded_R...in_SoCal#SoCal
post #4 of 16 Old 12-13-2010, 02:24 PM Thread Starter
08700xx's Avatar
I just talked to VP and they recommended U4.4 and gave me the number of a few places around me that have 55 gallon drums for sale.
Thanks for the link roadkill, this will help a lot.
08700xx is offline
post #5 of 16 Old 12-13-2010, 03:00 PM
skier207's Avatar
If your in need while at Glamis the Loves (exit 8 I believe) in Yuma has 100 and 110 octane.
skier207 is offline
post #6 of 16 Old 12-13-2010, 03:03 PM
Both the VP U4.4 and C12 are leaded fuels... OK for sanctioned racing, but NOT for public trails. If you just plan to race only, you'd be OK. But for a dual use fuel... racing AND trails... you might still be OK as I've never seen anyone check a quad to see if their fuel was leaded or not. Just don't pump from the drum that has "leaded" on it.
post #7 of 16 Old 12-13-2010, 03:17 PM Thread Starter
08700xx's Avatar
I didn’t think about that roadkill, thanks for the heads up. I better make sure I remove any stickers on the drum and keep it tucked away in my toy hauler.
08700xx is offline
post #8 of 16 Old 12-13-2010, 06:21 PM
Your best bet is to buy 100octane at a local pump its just easy.You don't want to mess with 4.4 for a daily rider oxy fuel is great for guys that race only but not practical for everyday use.
08 raptor 700
chris is offline
post #9 of 16 Old 12-13-2010, 06:39 PM
I used C12 in the race machines and now in the XX due to the big bore. A lil advice, change your oil more b/c it is leaded. Also, you can try Sunoco, I know alot of them around home for me have 104 to 108 Octanes that work pretty well. If that all fails, I hit the airport.
post #10 of 16 Old 12-13-2010, 06:58 PM
USMC0861's Avatar
Don't use a torch to take the sticker off easier....do this one the hard way
USMC0861 is offline
