leaking oil!! - Club700XX - Honda TRX700XX Forum
post #1 of 21 Old 12-12-2010, 11:31 PM Thread Starter
mrhonda700xx's Avatar
Send a message via Skype™ to mrhonda700xx
leaking oil!!
so i changed my oil like 3 weeks ago. this past weekend i was out riding and i noticed that oil was coming out of the dipstick..so i changed the o-ring. but then i went riding today and it started leaking the same..would it be that i have to much oil in there that its buiding pressure?
mrhonda700xx is offline
post #2 of 21 Old 12-12-2010, 11:42 PM
08700xx's Avatar
My buddy put too much oil in his Raptor once and said the same thing was happening to him. I believe our quads take 1.9 quarts but I’m sure someone a lot smarter than me will chime in on this for you.
08700xx is offline
post #3 of 21 Old 12-12-2010, 11:44 PM
TRX700XX's Avatar
1.9 is what the service manual says
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #4 of 21 Old 12-13-2010, 12:01 AM Thread Starter
yeah i put something like that on and i ran it for a little while so it can go back into the filter and then i put some more cause it needed more then now this is happening...
post #5 of 21 Old 12-13-2010, 08:16 AM
AusTrx700xx's Avatar
im not sure what the go is between quarts and litres, but i know mine used 1.8 litres, and i got a feeling (havnt read the manual in a while) you supposed to let the bike sit for 5 min after runnig before you check the oil level
All readyto roost thanks to
Mike at Quadparts.com.au
Team IMS imsproducts.com
George at MonsterLab Atv
Kimberly Motorcycles
Minshull Mechanical Repairs
AusTrx700xx is offline
post #6 of 21 Old 12-13-2010, 12:44 PM
Check your oil as per the manual.
Your most likely over filled and need to read the manual for the proper way to check your level. Remember this is a dry sump system.
post #7 of 21 Old 12-13-2010, 01:15 PM
There is a certain way to check your oil as well. You're supposed to warm the machine up for 5 minutes and let it sit for 2 minutes. After the two minutes you check the oil by simply dipping the stick, do not screw it in to check the oil. All of this can be found in the owners manual.
post #8 of 21 Old 12-13-2010, 03:59 PM
I usually put 2.1 litres in at oil change . Never had any issues. 1.8 in the oil tank and 300ml poured into the head through the rocker cover.
post #9 of 21 Old 12-13-2010, 06:04 PM Thread Starter
the problem is that once you start it oil comes out from the thread of the dipstick...
post #10 of 21 Old 12-13-2010, 06:18 PM
Sounds like there is way too much oil in there. Do you know how much you put in there?
