Anyone else notice the same on their xx? - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 12-20-2010, 07:07 PM Thread Starter
ara
This is normal on my crf, but never noticed it on the xx.
If the xx is in gear and motor not running, pulling the clutch lever does not dis-engage the gear to allow one to roll it around in the garage. I noticed it after installing a powermadd hand gaurd. BTW, I have not started the bike in maybe 6 months.
ara is offline
post #2 of 10 Old 12-20-2010, 07:23 PM
92K1500's Avatar
It does too. You just have to push it a little hard to break it loose.
My dads Harley does it as well as my XX. I've never paid attention to it because I've grown up around motorcycles. I think my sport bike does it but not as noticeable.
2008 Honda TRX700XX
AC Racing MX Nerf Bars.
PRM Desert Grab Bar.
92K1500 is offline
post #3 of 10 Old 12-20-2010, 07:42 PM
redrider's Avatar
yep, all my sport quads with a clutch have done this. The more you push it the less resistance you'll get.
6 months, man you need to get out and ride!!
redrider is offline
post #4 of 10 Old 12-20-2010, 08:39 PM
92K1500's Avatar
You might have to roll it the opposite way then roll it the way you want to go faster and it will break it loose. If you don't get that little bit of impact it will usually just drag the tires. (If you're on a polished concrete garage floor)
2008 Honda TRX700XX
92K1500 is offline
post #5 of 10 Old 12-20-2010, 08:53 PM
I dont think I have been on something that this doesn't do that. I know my 1000RR was really hard to move around, the 600RR is easier, but still there is some drag.
post #6 of 10 Old 12-20-2010, 09:05 PM
92K1500's Avatar
I haven't noticed it on my ZX6R but it might be because I don't think about it anymore.
2008 Honda TRX700XX
92K1500 is offline
post #7 of 10 Old 12-21-2010, 10:22 AM Thread Starter
ara
I've been riding my 2 wheelers about 2 or 3 times a week....lost some interest in the quads so they're just parked.
ara is offline
post #8 of 10 Old 12-21-2010, 10:28 AM Thread Starter
ara
Thanks for all the replies. I haven't touched the quads most of the year unitll yesterday when I tried to roll it and noticed it. I know some of my other bikes do that, just was't sure if the xx did also. Anyway, moved my bikes around today, and it seems this only happens on the Japanese bikes.
ara is offline
post #9 of 10 Old 12-21-2010, 04:11 PM
Also the xx doesn,t like to start in gear either (few things removed).
I had a KTM 520 didnt like to be pushed whilst clutch pulled in /in gear either.The only one that was easy was a Kawasaki and Honda 125 ,2 strokes I had.
post #10 of 10 Old 12-21-2010, 04:29 PM
i have stock grips and mine have never done this... i have about 1/8 of play in the lever
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
