knocking noise from bottom end... - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 12-23-2010, 11:41 AM Thread Starter
Was just wondering, I hear a knocking noise from the crank when she's warm, when I press on the clutch it goes away, it only does it when in neutral and the clutch is out. Is this normal or should I be worried about it.
NavyNut is offline
post #2 of 9 Old 12-23-2010, 03:17 PM
Try reading this, It should help.
https://www.club700xx.com/vb/showthre...clutch+bearing
post #3 of 9 Old 12-23-2010, 05:41 PM
Would this be considered a "Warranty Issue" if there is an updated part available?
Seabass is offline
post #4 of 9 Old 12-23-2010, 07:18 PM
you could argue , but I doubt it. Depends on youre dealer.
post #5 of 9 Old 12-23-2010, 07:45 PM Thread Starter
Ha ok, good to see its just the clutch bearing, how hard is it to replace ?
NavyNut is offline
post #6 of 9 Old 12-23-2010, 09:03 PM
its nothin dont worry about it. it's not ur clutch bearing... its just forb the grears spinnig freely... mine has made the noise since i got her new outa the crate
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
post #7 of 9 Old 12-23-2010, 10:20 PM
Simplyorange's Avatar
ine got bad, it toasted my basket and i just oput a new basket and ebc clutch pads, it is fine now. and honda will phuck you on the warranty as always, i tried that route, they claim improper clutch adjustment.
2007 GSXR 1000 (Orange/Black)
Simplyorange is offline
post #8 of 9 Old 12-24-2010, 02:45 PM
I had the same noise and i took it too a place and i spon the crank bearing. i got lazy with checking the oil and i was burning oil
Matt.Trx700 is offline
post #9 of 9 Old 12-25-2010, 01:45 PM Thread Starter
Thanks for the input guys, the quad is not under warranty anyways as I import it from the states to Canada.
Getting my stem fixed and will probably change the bearing for the new one just in case ;)
NavyNut is offline
