pistons 12:1 11:1? - Club700XX - Honda TRX700XX Forum
post #1 of 150 Old 12-28-2010, 11:55 AM Thread Starter
pistons 12:1 11:1?
ok i looked. really i did. and couldnt find anything on this, im planning on doing a build in the spring if all goes well. i dont here much about anyone running a 12:1. whats the pros and cons compaird to the 11:1. im gonna be running a stage 3 hot cam and porting the head. most my buddies run 13.5:1 in their 450s and all their quads haul ass and are not tempormental at all.
post #2 of 150 Old 12-28-2010, 12:14 PM
Mo powa!!! Somebody on here's got a 12:1 piston? Can't remember who though?
post #3 of 150 Old 12-28-2010, 12:47 PM Thread Starter
yeah nothing wrong with that and you can still run 91. i remember hearing that a few of matlocks blew up runing 12:1 but i will never be running my quad that hard.
post #4 of 150 Old 12-28-2010, 12:55 PM
jake99buell's Avatar
I think it comes down to what octane your willing to run. I think I read where someone claimed matlocks bike would grenade at 12:1 but not for sure. You aren't putting your bike through 500 miles of hell so I dunno.
jake99buell is offline
post #5 of 150 Old 12-28-2010, 12:55 PM
I didn't think you could still run 91 with 12:1 on a 700XX, I thought the 11:1 was about the max compression you could run on 91 octane. Might want to double check on that with an engine builder.
I can't imagine that a 12:1 piston would be any less reliable then a 11:1 piston, as long as you use the correct octane fuel with it.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #6 of 150 Old 12-28-2010, 01:02 PM
VelociRaptor's Avatar
I wouldnt, to be totally safe on premium pump you need to go no higher than 11:1
Bo White
205-886-7043
VelociRaptor is offline
post #7 of 150 Old 12-28-2010, 01:25 PM Thread Starter
it that just something for our type of engine? i guess im a little confused cause my buddy runs 91 in his canam 450 that has a 13.5:1 and it runs great and is fast as hell. and a lot of the 450 dirtbikes are 13:1 and run 91. thats why i figured it would be fine.
post #8 of 150 Old 12-28-2010, 01:28 PM
Yea is there an explanation as to why our bikes need higher octane with the same compression?
post #9 of 150 Old 12-28-2010, 02:18 PM
Ive explained this before here I believe Ill look and see if I can link it here.
Bo White
205-886-7043
post #10 of 150 Old 12-28-2010, 02:21 PM
I can elaborate even further if needed:
How did all of those '60s muclecars run around on the street from the factory on pump gas and 11:1 or more compression along with iron heads? The cam was bleeding off cylinder pressure and the use of leaded gas. How does all of these crotch rockets and450s run around doing the samething today? Camshaft profiling and technology in FI and combustion chamber shapes.
Bo White
205-886-7043
