Help! - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 12-30-2010, 05:57 PM Thread Starter
scameron92's Avatar
Help!
This isn't a 700XX question but here goes. My son's raptor 80 won't start. Has fuel and good spark. It won't even start by squirting starting fluid straight into the cylinder. I tried a new plug. Tore the carb apart and cleaned the jets. Drained the tank and put new gas in it. Any help would be greatly appreciated.
2008 trx700xx
1992 250x (sons)
2005 crf230
2005 LTZ250 (sons)
scameron92 is offline
post #2 of 8 Old 12-30-2010, 06:08 PM
skier207's Avatar
Try a compression check.
skier207 is offline
post #3 of 8 Old 12-30-2010, 06:24 PM Thread Starter
scameron92's Avatar
I dont have a tester, but I dont think it would be anything major(internal). He was riding it about 3 weeks ago and it ran fine. Went to get it out and it wont start
2008 trx700xx
1992 250x (sons)
2005 crf230
2005 LTZ250 (sons)
post #4 of 8 Old 12-30-2010, 06:38 PM
skier207's Avatar
If it has fuel and spark that leaves 4 things, flooded, plugged exhaust, compression, timing.
skier207 is offline
post #5 of 8 Old 12-30-2010, 06:54 PM
If you suspect compression, you can see if it will blow your thumb off the spark plug hole for a quick check. Just make sure to get the plug cap out of the way so you don't taze yourself.
post #6 of 8 Old 12-30-2010, 08:21 PM
Can do the same thing w/ the exhaust to see if you are getting anything out of the end as well. Is it a manual? If so, try popping it.
post #7 of 8 Old 12-30-2010, 08:32 PM Thread Starter
scameron92's Avatar
Got it fixed. It was the battery. Cranked over fine but apparently it wasnt putting out enough amps to start it. Thanks for all the suggestions
2008 trx700xx
1992 250x (sons)
2005 crf230
2005 LTZ250 (sons)
post #8 of 8 Old 12-31-2010, 12:43 PM
WILDMANNUM1's Avatar
Even though you already have it fixed one thing to watch for on those quads is that the screws that hold the choke plate on vibrate lose and get sucked though the engine. usually tearing up the head valves piston and cylinder along the way
WILDMANNUM1 is offline
