Oil In air box - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 01-02-2011, 08:55 PM Thread Starter
Oil In air box
Seems to be after every ride i have a puddle of motor oil in the bottom of my air box of oil. its not air filter oil..any ideas?
tomtalbot10589 is offline
post #2 of 7 Old 01-02-2011, 10:47 PM
mrtheandrew's Avatar
its possible too much oil was serviced into the motor at the last oil change.
mrtheandrew is offline
post #3 of 7 Old 01-03-2011, 10:48 AM
trx700's Avatar
Change your oil and filter to besure that its done right. Make sure it is on level ground when checking the oil. Top it off slowly so you don't over fill it. mrthandrew is probably right.
2008 Black & Red TRX 700XX
trx700 is offline
post #4 of 7 Old 01-03-2011, 11:40 AM
Totally agree!! Make sure the engine is warmed up before checking the oil level. Use the Owners Manual as a guide.
post #5 of 7 Old 01-03-2011, 04:16 PM
240
If your oil level is fine do you do long wheelies? I know if I went riding and did wheelies for an extended amount of time a little bit would get in my air box.
240 is offline
post #6 of 7 Old 01-03-2011, 04:21 PM
I second the wheelie thing nerv, everytime i ride wheelies i get oil in the airbox.
post #7 of 7 Old 01-05-2011, 04:02 PM
This has happened twice with me :
Once when I stood it on the rear grab bar and the second when the engine got too hot.
