Header wrap - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 01-04-2011, 03:34 AM Thread Starter
hmfman91's Avatar
Header wrap
Well for Christmas I got a thing of Titanium header wrap for my XX. I have the Barkers exhaust but the heat shield fell off like 3 wks after I installed. I have to say...it actually looks good and works awesome. Im glad I got some cause I have a nasty scar and my leg from the pipe lol. If any of you guys/gals have a problem with the excessive heat I highly recommend header wrap. I think it was from Advance Auto Parts.
2008 RED/BLACK 700xx
hmfman91 is offline
post #2 of 12 Old 01-04-2011, 06:02 AM
Was just looking at wrap lastnight for my exhaust. Is it the 1" or 2" width and do you know how thick it is? I think standard is 1/16" but for more heat control they also sell 1/8".
Also can you take some pics?
NineLivez2Go is offline
post #3 of 12 Old 01-04-2011, 09:40 AM
This is what I'm suppose to be getting today, hopefully!!
http://paceperformance.com/i-5136739...-in-color.html
Will install it and hopefully have a chance to try it out this week.
post #4 of 12 Old 01-04-2011, 02:13 PM Thread Starter
hmfman91's Avatar
Im pretty sure mine was 2" wide. It said to leave a 1/4" overlap but I left more like 1/2" of overlap, it still looks and works fine. Here's a couple of pics.
hmfman91 is offline
post #5 of 12 Old 01-04-2011, 02:32 PM
holy700xx's Avatar
Looks good. Interested to see how well it keeps the heat away from you leg. Also how it works with water/mud splashing up. I'm looking for something to keep my leg from burning during the warmer months, however the trials get quite muddy in Maine.
holy700xx is offline
post #6 of 12 Old 01-04-2011, 02:54 PM
TRX700XXX's Avatar
Did you take off the mounting holes for the heat sheild or just go over them?
TRX700XXX is offline
post #7 of 12 Old 01-04-2011, 05:54 PM
Wrap Look's Awesome,Great Tip for the Exhaust.
2008 trx700xx,DG Muffler,FMF fuel Management, 13 tooth frt sprocket,Alba Pro elite nerf bar's for now.
busbill1300 is offline
post #8 of 12 Old 01-04-2011, 06:46 PM
jake99buell's Avatar
I have mine wrapped and it keeps the heat off my leg but I got supper muddy and now it is brown. It caked on them baked on. Looked sweet at first but I really didn't do it for looks.
jake99buell is offline
post #9 of 12 Old 01-04-2011, 08:23 PM
Looks good man, thanks for the pics. I was told to go with the 1" wide wrap because of the smaller diameter pipe and the 2" wrap on the bends would not lay flat, but yours looks fine.
post #10 of 12 Old 01-04-2011, 08:50 PM
You let it soak in water for a few minutes and it becomes pretty playable and easier to work with. I did mine still on the bike. I only wrapped a little past where my leg goes. I also took the mounting brackets off for the heat shield. I broke every worm gear clamps
