Power Commander Auto Tune - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 01-12-2011, 03:15 PM Thread Starter
Does anyone know much about these? Power Commander makes it sound like these things will completely fix your map so if you can get it close at all then this makes it golden. Almost sounds too good to be true to me
post #2 of 11 Old 01-12-2011, 03:23 PM
It's supposed to be pretty good, you turn it to learn mode, run it hard through the gears for about 20 minutes, plug the laptop look at the trim changes and if you agree you click on accept and all changes that the autotune sensed needed changing are changed. Yo have to have a map that is pretty close so the autotuning is faster.
2006 Raptor 700
post #3 of 11 Old 01-12-2011, 04:25 PM
boost addict's Avatar
Crash.... Have you read this post before?
https://www.club700xx.com/vb/showthre...highlight=alba
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #4 of 11 Old 01-12-2011, 06:35 PM Thread Starter
I did not read that thread before but I like how it sounds and fuel moto said almost the exact same thing when I called to pick their brain today. They said they were amazed at how close it made the map!
post #5 of 11 Old 01-12-2011, 06:52 PM
I can post the fuelmoto map and the Sparks map, if you want to see the difference in the maps.
Ed @
Chris & Mike
post #6 of 11 Old 01-12-2011, 07:22 PM Thread Starter
I talked to fuel Moto and they don't do any atv maps so the fuel Moto one will be one of the ones off the power commander website the guy said
post #7 of 11 Old 01-12-2011, 07:37 PM
Call Sparks, their map is a custom dyno tune. I will have mine in for a base dyno run in the next week or two.
Ed @
Chris & Mike
post #8 of 11 Old 01-14-2011, 02:43 PM
The map on the PCV I sent you may be pretty close to what you need. I found it to be a little rich on my setup though. Never was able to find a decent tuner in my area.
post #9 of 11 Old 01-14-2011, 03:06 PM Thread Starter
Sounds good. Can't wait to get it
post #10 of 11 Old 02-21-2012, 10:31 AM
Does anyone have an autotune they'd let me borrow if I were to buy a PCV?
I only need it temporarily, right?
