motor protection - Club700XX - Honda TRX700XX Forum
post #1 of 22 Old 01-18-2011, 09:52 AM Thread Starter
motor protection
well i had to redo my top end on my quad. now that im up and running again i want to prevent dirt and dust from entering the engine.(im told that i had dust in my engin and it burnt out my rings, cylinder, and piston head.) right now im running my stock box/lid and a uni filter. any suggetions would be appriciated. thanks
OFUD is offline
post #2 of 22 Old 01-18-2011, 10:06 AM
AusTrx700xx's Avatar
clean/check your air filter after every ride. what air filter oil you using, and how often do you re oil it?
All readyto roost thanks to
Mike at Quadparts.com.au
Team IMS imsproducts.com
George at MonsterLab Atv
Kimberly Motorcycles
Minshull Mechanical Repairs
AusTrx700xx is offline
post #3 of 22 Old 01-18-2011, 10:13 AM
I clean my airbox after every ride. I will take the filter off and inspect it. If it even looks dirty or like it needs oil then i change it out. If i ride in a dusty situation where my air filter got really dirty. Then i clean airbox and replace filter with a clean and oiled one. I would also change out the motor oil and oil filter incase some dirt got past my air filter.
post #4 of 22 Old 01-18-2011, 10:14 AM
It's good to have a couple uni filter's that way you always have a clean one ready to use!
post #5 of 22 Old 01-18-2011, 10:45 AM
Simplyorange's Avatar
put an outerwears over it.
2007 GSXR 1000 (Orange/Black)
Simplyorange is offline
post #6 of 22 Old 01-18-2011, 10:54 AM
boost addict's Avatar
x2 put an outerwears over it.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #7 of 22 Old 01-18-2011, 11:22 AM
http://cgi.ebay.com/ebaymotors/Outer...Q5fAccessories
post #8 of 22 Old 01-18-2011, 11:43 AM
There seems to be allot of ring failures due to dust in these motors. I honestly believe it's a design flaw in the pistons. I've tore my motor apart quite a few times with variable hours and have noticed wear on the skirts.
Even on tear downs with 10-20 hours there was noticeable wear. It seems these slipper pistons are a bit to short causing added stress to the rings. If my thoughts have any ground this would explain some of the noise you hear in these motors also. ( the piston shuddering in the bore )
But anyway, I'll stop rambling. The best protection for dust would be a Uni filter with an outerwear. If enough dust entered the motor to wash out your rings the TB should be noticeably dirty as well. Check it out and clean as needed too.
post #9 of 22 Old 01-18-2011, 10:05 PM
240
Does that 450r outerwears fit the 700xx uni filter?
240 is offline
post #10 of 22 Old 01-18-2011, 10:24 PM
Uni and an Outerwear on the lid IMO, less mess. Or both if you want to double bag it.
