Best way to clean air filter - Club700XX - Honda TRX700XX Forum
post #1 of 22 Old 01-19-2011, 08:18 AM Thread Starter
holy700xx's Avatar
After looking at the thread on motor protection I'm wondering how you all clean your air filter, what you have, and how often you clean it.
holy700xx is offline
post #2 of 22 Old 01-19-2011, 11:57 AM
Follow the instructions in the service manual, there's allot of threads covering thIs also.
post #3 of 22 Old 01-19-2011, 12:28 PM
08700xx's Avatar
Depends on what kind of filter you have. I use K&N filters with 2 outerwear’s over it with no air box lid. I have 4 K&N filters that I keep cleaned and oiled so I can just change them out after my ride each night. If you have a K&N filter just get the recharger kits and follow the directions.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #4 of 22 Old 01-19-2011, 01:02 PM
i have Uni's with the EHS lid. I just clean out my airbox and inspect my filter after every ride. Some times i'll change it after one ride and sometimes i'll get 2 or 3 rides out of it. Just depends on how dirty it looks. I don't let it get really dirty before i change it. I use the Uni filter cleaner and oil and follow the instructions. The Uni oil is good stuff it's super sticky and doesn't run off like other filter oil's i have used.
post #5 of 22 Old 01-19-2011, 04:36 PM
TRX700XXX's Avatar
I have EHS lid with side vents and uni filter. I got foam filter cleaner that you spray on and let it sit for 15 minutes then rinse off with water. Then wait for it to dry and spray the oil on the filter and your good to go.
TRX700XXX is offline
post #6 of 22 Old 01-19-2011, 05:47 PM Thread Starter
holy700xx's Avatar
I also have a uni. Guess I will have to get some of the uni cleaner and oil.
post #7 of 22 Old 01-19-2011, 06:07 PM
I use a Twin Air filter cleaning kit but not there filter oil. Clean filter every ride and bought 5 250r Uni filters and clean 4 at a time so I always have a spare.
post #8 of 22 Old 01-20-2011, 09:25 PM
I know after reading of this potential problem I will be buying an extra filter to rotate with. Oil changes and air filter cleanings are cheap insurance.
500Rubie is offline
post #9 of 22 Old 01-23-2011, 07:33 PM
trx700's Avatar
I bought a UNI filter and an OuterWear filter. The Filter does not fit the stock or Uni Filter. Only the K&N filter. So this is what I did with the Outerwear.
Stock filter
UNI Filter
OuterWear Pre-Filter
2008 Black & Red TRX 700XX
trx700 is offline
post #10 of 22 Old 01-23-2011, 08:48 PM
Overlord's Avatar
A good process
Folks I run the Pro Design with the red pre filter and no lid. In Aus we have microscopic dirt particles (BECAUSE IT IS SO DRY) and its not what filter you have, its how often you clean it and how.
1. Buy to 10 litre buckets with lids you can seal.
2. Fill each one with 5 liters of Turps or Kero. (I like Turps)
3. Have one as the first clean, then the second one for the final clean
4. I then rinse the filters out in soapy water then rinse with clean water.
5. Hang on line to dry.
6. Oil filter
This may sound a bit of a hassle but once your set up its a 5 min process. I live in one of the driest countrys on earth and I have lived by this process ever since I started riding 35 years ago and have never dusted a motor, quad or dirt bike.
Folks this set up lasts about a year before you have to change the Turps or Kero maybe less if your racing and by the way keep the buckets in a cool place so they dont expand.
HMF Bill Ballance full system with HMF controller, Pro design Filter and billet adaptor,
Fox Evolve Gen 2 with Houser +.75 arms,
Fox Podiums with Shock Pro skull covers,
OMF re-enforced front and rear with Kenda XCF up front and of course Kenda Kutter's on the rear,
Trail Tec bars, clamps and dash.
ASV Lever,
Braided lines and billet clamps,
Moto Active nerfs and Bumper,
AMF Graphics
OZlink gets his Kutters from me
Overlord is offline
