Post your engine/trans problems and solutions - Club700XX - Honda TRX700XX Forum
post #1 of 21 Old 01-24-2011, 10:34 AM Thread Starter
Simplyorange's Avatar
here are mine and some solutions i came up with after getting sick and tired of engine noise and tearing the whole motor apart.
problems:
clutch bearing going out(more than 1 time)
connecting rod small end wore out causing piston to walk and engine to smoke
i assume valve seals are leaking
timing tensioner went out
i believe the wrist pin failure was do to oiling loss because of a clogged oil screen, there are 2 or 3 in the engine that i am going to check today.
solutions:
for the tensioner i can easily make a stock tensioner into a manual one or the 2006 xr650r tensioner works too and are easily found on ebay.
for valve seals, order 2006 xr650r valve seals off of ebay, they are the same seal at a fraction of oem cost.
when the connecting rod is gone, have your local machine shop bore out the hole and install a 0.945 in. I.D. chevrolet bronze bushing in it instead of buying a $350 crank assembly, that way if it goes out again you can just change the bushing.
check all screens listed in the service manual to make sure they are not clogged.
honda offers a replacement clutch basket bearing for some reason so im going to try that.then i will move on to another option.
my solution to the clutch chattering problem, i plan to see if it is possible to use a xr650r clutch assembly since they do not have issues with clutch basket noise and our engines were designed based off of that motor except with a different rod length and piston bore.if i find someone willing to let me use thier xr650r clutch assembly then ill post up my findings.
post up your problems and solutions, i have done tons of research to find affordable upgraded fixes for my problems so hopefully this helps someone in the future.
2007 GSXR 1000 (Orange/Black)
Simplyorange is offline
post #2 of 21 Old 01-24-2011, 11:53 AM
So far I haven't had any problems with my motor.
post #3 of 21 Old 01-24-2011, 11:58 AM Thread Starter
i hope nobody does because its a stressful, expensive, PITA process of repairing it.
post #4 of 21 Old 01-24-2011, 05:50 PM
Just to help you out, somebody () makes a conrod kit, can't remember who but i will find it .They also do valve stem seals.
And I beleive Wayne said you could you use the 650r clutch(?) but did not specify anymore.
post #5 of 21 Old 01-24-2011, 06:11 PM
Pro X does the valve seals and Hotrods does the conrod kit,
http://www.hotrodsproducts.com/Produ...x?item_id=4336
post #6 of 21 Old 01-24-2011, 06:31 PM
Blak92's Avatar
Should we start a sticky pole or something to keep track of how many end up with these problems? Mine has almost 200hrs and not a problem one. Yet.
Blak92 is offline
post #7 of 21 Old 01-24-2011, 06:37 PM
boost addict's Avatar
The xr650 valve seals can be found here.
http://valvetrain.kpmivalvetrain.com...v/700-100018-4?
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #8 of 21 Old 01-24-2011, 09:53 PM
Great post Jarrod, I like the idea of repairing the con-rod.
post #9 of 21 Old 01-25-2011, 09:04 AM Thread Starter
thanks for the info, that is why i started this thread, to put all findings in one location...hopefully he will chime in about the clutch because if it is true then that may be the route i am going.
im going to research the connecting rod, its $150 and if it does not have a bushing, the next time it goes out you have to spend another $150 to replace it,designing it like a car engine means you can spend $28 to have a new bushing pressed in, the origina;l cost to have the hole machined and the bushing pressed in, cut and chamfered is about $58, the bushing is $8 of that price
btw, it uses a connecting rod small end bushing for a Z06 LS6 corvette available from howards racing cams from summitracing.com
post #10 of 21 Old 01-25-2011, 10:07 AM
my enigine sota (locked up) .... somethin with the decomp, it sorta got stuck..... runnin fine now. i just messed with it and i fixed it...somehow 0.0
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
