shuts down on long hills? - Club700XX - Honda TRX700XX Forum
post #1 of 33 Old 01-29-2011, 03:50 PM Thread Starter
the problem im having is shutting down and it seems to happen on hills, not all the time just random . im running an fmf pipe and fmf programmer twin air closed lid. has anybody else had this problem or any ideas what the problem could be?
you dont stop riding because your to old, you get old because you stop riding!
ssxr600 is offline
post #2 of 33 Old 01-29-2011, 04:26 PM
How many hours on your bike? HAve the valves been adjusted?
post #3 of 33 Old 01-29-2011, 04:44 PM
Sounds like you having a fuel cutoff, have you check your fuel filter and is your petcock set to reserve which might cause it but sounds more like a fuel filter issue which could also be something in your tank which is why it's only an intermittent issue.
post #4 of 33 Old 01-29-2011, 05:36 PM Thread Starter
nash the filter was checked and its not on res, but i havent checked the tank yet but i will. red n black it has low hours and the valves were checked after breakin but its due to be check again
ssxr600 is offline
post #5 of 33 Old 01-29-2011, 08:05 PM
i went over 100hr be4 my valve went outa spec... what are ya revs like when it stalls...
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
post #6 of 33 Old 01-30-2011, 04:36 PM
DL700's Avatar
up hill or down?
DL700 is offline
post #7 of 33 Old 01-30-2011, 05:30 PM Thread Starter
up never down
ssxr600 is offline
post #8 of 33 Old 01-31-2011, 01:48 AM
DL700's Avatar
check the plug after it turns off, possible a lean issue , id check the rollover switch or lean angle sensor what ever they call it for secure attatchment
DL700 is offline
post #9 of 33 Old 01-31-2011, 06:19 AM
It's hard to trouble shoot issues like this over the net. Are there any other details u can provide? Is it a steep hill, does it pop or loose power or simply dies. What does it take to get it started again?
Something to keep in mind is the lean condition the bikes are stock and the lean condition programmers and exhaust can cause. Under heavy loads you could experience detonation even with stock compression. It's always best to run 91/93 octane to curb this.
post #10 of 33 Old 01-31-2011, 01:48 PM
When mine wouldn't idle it was because the valves were WAY out of spec. I'm not saying that this is what is happening to you, but rather what was going on with me on mine when it would shut off.
