New Cam Install - Club700XX - Honda TRX700XX Forum
post #1 of 55 Old 01-30-2011, 02:37 PM Thread Starter
1dmbhonkey's Avatar
New Cam Install
Just ordered hot cams stage 2 cam. Anyone got any install tips I should know before I tear into this thing. The manual says I need a special tool for the cam chain tensioner. Does anyone know if you can get around that?? Also I couldn't find a torque spec for the valve cover bolts .... anybody know what spec is??
1dmbhonkey is offline
post #2 of 55 Old 01-30-2011, 02:54 PM
Simplyorange's Avatar
the special tool can be replaced with a small flat head screwdriver...valve cover bolt tq is not listed in the manual, i would do them to 19ft lbs, i got that number from the 400ex service manual.
2007 GSXR 1000 (Orange/Black)
Simplyorange is offline
post #3 of 55 Old 01-30-2011, 04:50 PM
Same here, I use a small screwdriver. Works perfectly.
post #4 of 55 Old 01-30-2011, 05:04 PM
Those valve cover bolts are in the manual, you have go look them up as the bolt size. I want to say they are 6.5 ft lbs of torque only
post #5 of 55 Old 01-30-2011, 05:58 PM Thread Starter
1dmbhonkey's Avatar
Do you have to keep tension on the screwdriver to keep the tensioner back?? The bolts on the valve cover are 8mm and 6mm
post #6 of 55 Old 01-30-2011, 06:14 PM
As for the tensioner yes. A pair of needle nose vice grips take care of that. Make sure with the bolt sizes you look up the actual bolt size and not the head size. I snapped one when I did it wrong the first time. Then go into the manual and look up torque values
post #7 of 55 Old 01-30-2011, 06:26 PM
ok, i didnt look at them right, disregard the specs in my first post..im going to look them up in a little while.
post #8 of 55 Old 01-30-2011, 06:30 PM
Cranedaddy's Avatar
Be sure and let us know how much difference the cam made!
Stock 08 TRX700XX
Cranedaddy is offline
post #9 of 55 Old 01-30-2011, 07:52 PM Thread Starter
1dmbhonkey's Avatar
I wasnt sure if i should get the stage 2 or not since i only have a slip-on pipe. I have the Mod quad K&N intake too but i like to keep the airbox lid on.... anybody running a similar combo
post #10 of 55 Old 01-31-2011, 05:50 AM
To remove the tensioner you can simply unbolt it without the use of the screwdriver. To reinstall it you insert the screwdriver and wind it up, u hold the tension until you tighten the tensioner down. It doesn't take much effort to wind the tensioner up but you Cannot screw the tensioner down without winding it up.
