What looks like better port work? - Club700XX - Honda TRX700XX Forum
post #1 of 34 Old 02-01-2011, 10:41 AM Thread Starter
Im pretty sure i know what response i will get from this but its something i always kinda wondered. I tested it on guys in my shop and they gave me answer's i thought the general consumers would which suprised me. Im going to call this market research its not done to make anybody mad.
from these pictures what looks like better port work what would probably make more power and why? these are a stock valve 700xx head
people like bo please dont comment on this just yet i am curious what general people think, and dont think about to hard just give your first response ewwa, uhh ahh, 1 looks better becuase its shinnyer, 2 is better cause its bigger and shiny, 3 just cause, 4 because its rougher and will do something to the air. you know something simple
EHSRACING is offline
post #2 of 34 Old 02-01-2011, 10:49 AM
1 and 2 look about the same to me 4 does look rough and smmes to have more materieal on the spline where they join toghter 3 looks like it could be polished a bit more but may just be that its a different angle.2 actually looks like the spline (center section is straighter than one if that makes since. there rambling from some one that knows very little about porting.
post #3 of 34 Old 02-01-2011, 11:04 AM
Simplyorange's Avatar
im going to go with it doesnt matter how it looks, the flow bench tells the tale.
2007 GSXR 1000 (Orange/Black)
Simplyorange is offline
post #4 of 34 Old 02-01-2011, 11:08 AM
im gonna say 4 because there is more material removed.
post #5 of 34 Old 02-01-2011, 11:38 AM
I know de answer boss! (raises hand)
post #6 of 34 Old 02-01-2011, 11:41 AM
Rith's Avatar
\0.o/ I unno, give me charts with numbers and I can tell ya The bottom one looks kind of rough I guess
08' TRX700xx - Red n' Black
Big Gun EVO r Exhaust
00' CR250rintintin
Rith is offline
post #7 of 34 Old 02-01-2011, 11:51 AM
08700xx's Avatar
I have no idea, thatís why I'm glad I found a good builder close to me that can help me out lol. To me it looks like different stages in the porting process
(DL700)
Jody (Boost Addict)
08700xx is offline
post #8 of 34 Old 02-01-2011, 12:08 PM
ziggy's Avatar
To me they all look the same... are they just different angles from the same step in the process?
2008 700xx -Blk-n-Gry (the faster one
13 Tooth Renthal Sprocket, L8ton Racing sway bar (both),MotoActiv Chivarly Bumber, EHS BIG 3, Kenda Kutters!
ziggy is offline
post #9 of 34 Old 02-01-2011, 01:26 PM
Looks like 4 has the vavle guides ground down further so you might be able to flow more. Give 4 a polish and I'd say that one. I like to know the end result, very interested.
post #10 of 34 Old 02-01-2011, 01:59 PM
Cranedaddy's Avatar
+one
Stock 08 TRX700XX
Cranedaddy is offline
