Need help with piston install from expierienced builders. - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 02-01-2011, 03:08 PM Thread Starter
Simplyorange's Avatar
today i was measuring my specs for my 11:1 CP piston and cylinder... below are the measurements i got, i need to know if they are acceptable. the reason i ask is bcause the CP piston kit came with a paper that lists certain tolerances, and they differ from the service manual tolerances.i want to make sure i have a second opinion before i grind on a ring.
below are actual measurements
Cylinder:
0.004 out of round
I.D. 4.018(skirt sides)
4.014 (end of pin side)
Piston:
O.D. 4.014
top ring end gap: 0.016
2nd ring end gap: 0.012
cylinder to piston clearance is 0.004 at the biggest part.
below are the service manual specs:
cylinder:
I.D. (4.0157-4.0163)
out of round (0.004 max)
Piston:
O.D. (1.014-4.105)
top ring end gap( 0.010-0.014)
2nd ring end gap(0.016-0.022)
cylinder to piston clearance: 0.0004-0.0022
below are CP specs
these specs came on the paperwork with the piston.
top ring end gap: 0.020
2nd ring end gap: 0.024
cylinder I.D: 4.0157
cylinder to piston clearance: 0.0020
piston O.D. 4.0137
im making an excel cahrt now to get a better idea of what i need to do and i already know what needs to be tweeked but i want to have a second opinion.
2007 GSXR 1000 (Orange/Black)
Simplyorange is offline
post #2 of 9 Old 02-01-2011, 06:01 PM
You would use the CP clearances, Neither cylinder you have had a better piston/cylinder clearance?
post #3 of 9 Old 02-01-2011, 06:06 PM Thread Starter
im going to check my original one tomorrow, i just got the crank assembly in and put the piston in my old cylinder and it is tight, like stock tight, im thinking just my piston was worn.
post #4 of 9 Old 02-01-2011, 08:59 PM
I would use the piston suppliers recommendation. What are you measuring with?
Smooth, just curious why the 2 wouldn't work great on the clearance? Something about CP pistons?
Edit: Nevermind, I read it again.
post #5 of 9 Old 02-01-2011, 10:31 PM
you need to set your rings to what cp says i personally like .018-.020 on top and and extra .002-.004 on the 2nd ring .012 is to tight
.002 per side is not bad when i had custom pistons made up a had them make them with a little extra room like that when you dont have the anti friction coating on them they need some extra oil room.
EHSRACING is offline
post #6 of 9 Old 02-01-2011, 11:19 PM Thread Starter
i know i have to gap the rings which i am not afraid of and your preference is pretty much exactly what i came up with..the piston to cylinder clearance is 0.004 right now on the skirt side, on the adjacent edges it is more like .0004...this worries me so im going to mic the other clinder i have tomorrow. we were using snap guages and mic tools that our machinist use al work to spec cmpressor pistons and such, tomorrow im going to try it with a digital micrometer to see if i get any different numbers.
i wantr this hing perfect when it goes back in, i dont want any issuse with it anymore.
post #7 of 9 Old 02-02-2011, 11:53 AM Thread Starter
eric, your comment just made me realize something, there is a 0.004 difference in the piston and cylinder diameter but that is a 0.002 clearance on all sides, which puts it within spec, with that being said everything will be spot on after i gap the rings today.thanks for your help, the smallest input can sometimes solve a problem.i guess with all of the measuring i was doing, i overlooked splitting the difference for the wall clearance.
post #8 of 9 Old 02-02-2011, 01:37 PM
dont worry i have a lot of those moments its usually the simple things that get you
post #9 of 9 Old 02-02-2011, 08:12 PM
That is too good!
