Draining the radiator - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 02-07-2009, 10:01 PM Thread Starter
aschuck's Avatar
Can someone tell me the best way to drain the radiator?
I'm adding the Temp sensor for my Vapor.
Is there a drain bolt or do I take off the lower hose?
A picture would be great.
My manual is one the way, but doesn’t do me any good in the mail.
Thank’s
Alex
aschuck is offline
post #2 of 10 Old 02-07-2009, 11:24 PM
vfm2010's Avatar
Without looking, I would guess there might be a drain on the bottom of the water pump. I'll check it out in the morning.
88 LT500R QUADZILLA
06 DVX400 (Son's)
06 TRX250EX (Wife's)
vfm2010 is offline
post #3 of 10 Old 02-07-2009, 11:52 PM Thread Starter
aschuck's Avatar
Thank's
I appreciate it!
aschuck is offline
post #4 of 10 Old 02-08-2009, 08:50 AM
The simplest way is to just pull the lower hose and drain it all in a bucket to reuse.
post #5 of 10 Old 02-08-2009, 03:24 PM
You can cut the hose without fluid running out. I installed mine and only got a little on the ground. I used a pair of the PVC cutters that look like pliers and it cut real easy.
Dave01 is offline
post #6 of 10 Old 02-08-2009, 08:50 PM Thread Starter
aschuck's Avatar
Thank's guys it's done.
wasn't to bad.
Dave01
where did you conect the power and grounds, right to the battery?
Thanks
Alex
aschuck is offline
post #7 of 10 Old 02-09-2009, 12:31 AM
wasn't to bad.
Dave01
Thanks
Alex
Alex, I went right to the battery to make sure I got a good ground and a full 12 volts.
Dave01 is offline
post #8 of 10 Old 02-09-2009, 09:17 AM Thread Starter
aschuck's Avatar
That's what I thought.
Thank's
aschuck is offline
post #9 of 10 Old 02-09-2009, 06:48 PM
Chrisj's Avatar
How did all you guys wire the RPM sensor. What value did you set your trailtech at?
Chrisj is offline
post #10 of 10 Old 02-09-2009, 07:42 PM Thread Starter
aschuck's Avatar
Good question!
I wraped it around the spark plug wire about 6 times.
I haven't set it up yet.
I would like to know the value also.
aschuck is offline
