stock 700xx backfire - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 02-06-2011, 08:28 AM Thread Starter
hi guys, i did try to search but found nothing on this. i recently bought this atv and on deceleration it ll backfire sometimes. atv is stock. what s the cause of this ? normal?
pascalr1 is offline
post #2 of 11 Old 02-06-2011, 08:33 AM
its running too lean from factory you need to get a fuel controller , it richens it up and will run a little cooler too .mine did that too stock.
post #3 of 11 Old 02-06-2011, 02:06 PM
yeah mine has the same thing going on
FAT-T 88 is offline
post #4 of 11 Old 02-06-2011, 09:37 PM
I recently purchased a ATV of a differant brand, that back fired when you let off of it. And after runing a few tanks a gas thru it, it was fine. So I wouldn't pull the panic plug right away!
post #5 of 11 Old 02-08-2011, 08:30 AM
should it be anything to worry about in cold weather? Like say.... around 20 degrees? I plan on runnin my stock xx this weekend for the first time, an it'll be in 20 degree weather.
manchvegas is offline
post #6 of 11 Old 02-08-2011, 08:41 AM
holy700xx's Avatar
No, Ive run mine at -10
holy700xx is offline
post #7 of 11 Old 02-09-2011, 09:49 AM Thread Starter
-30 here ! haha I win.
Thanks guys for the info !
pascalr1 is offline
post #8 of 11 Old 02-09-2011, 11:15 AM
well that makes me feel alot better about runnin in 20 degrees haha.
post #9 of 11 Old 02-09-2011, 08:01 PM
atleastitsnotaford's Avatar
I rode mine today @12 degrees.
knew someone that pulled the spark arrestor out of the stock muffler, and it would pop like that. He rode the hell out of it like that and the only problem it ever had was that sometimes, it would pop, and stall if you let off then right back on at low rpm.
atleastitsnotaford is offline
post #10 of 11 Old 02-12-2011, 07:04 AM
also make sure you run high octane gas. the lower cheap stuff will cause it to back fire. my old 420 rancher and my xx both did it
OFUD is offline
