Popping & stalling at full throttle? - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 02-06-2011, 11:25 PM Thread Starter
My 700 starts popping, back firing, & sometimes stalling when I'm at WOT. It idles and runs fine at lower RPM. It didn't do it one day but the next it did. I have a full FMF exhaust(powerbomb/4.1), EHS lid kit, EHS controller, & UNI filter. Did the programmer act up on me?
2008 TRX700XX Black on Black(the fastest one), Pro Armor Fat Peg Nerfs, Moose V-Front Bumper, EHS Lid Kit, EHS Controller, UNI Filter, FMF Powerbomb/Factory 4.1 Exhaust, Trail Tech Computer/Bar clamp, Trail Tech High Rise X bars, ODI Lock-On Grips, & Powermadd Handguards
Future Mods: ITP 10" rims Black & RAZR IIs on all fours
2006 Rincon 680 - 25" Mud Lite XTRs, Warn XT25 winch, Exhaust tip
Future mods: Fuel Controller, EHS Lid, Uni Filter
jason_hildo is offline
post #2 of 6 Old 02-07-2011, 01:58 PM
mrtheandrew's Avatar
what settings are you running on your controller? sounds like you need to adjust your high rpm (red) setting...
mrtheandrew is offline
post #3 of 6 Old 02-07-2011, 02:00 PM
08700xx's Avatar
Thatís what I was thinking or maybe some bad gas or spark plug.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #4 of 6 Old 02-07-2011, 02:14 PM
yeah... check your plug. sounds to me like its a little lean at high rpms. bump up the red setting by .5 or 1 and see if it helps at all. if it makes it worse, go the other way.
post #5 of 6 Old 02-07-2011, 02:31 PM
1. see if the lights are on when the bike is running
(makes sure the controller is still ok at least getting power or the ground didnt come loose)
2. add some fuel to the red like suggested shouldnt off needed unless it was takin down i have seen them get bumped during riding if they were placed where they can get squished or something of that sort.
3. it could be a fuel delivery issue like plugged filter etc where there just isnt enough supply getting there havent seen this at all on the xx a lot of 450's it happens a lot though. but that will be the symptoms no matter how much fuel you add with the controller it just doent have the psi to make any difference
EHSRACING is offline
post #6 of 6 Old 02-09-2011, 12:34 PM Thread Starter
I'll try those suggestions, I have the controller mounted inside the airbox so I don't know if it could have got bumped. I have had the quad for about 10 months & put on 1000miles so far and haven't had todo any work to it.
