Motor Build - Club700XX - Honda TRX700XX Forum
post #1 of 46 Old 02-09-2011, 06:21 PM Thread Starter
Motor Build
This is a tough one but I like the 14t in 1st,2nd and 3rd through the trees but running a stock motor and exhaust , 5th it seems too tall a gearing.Kinda want to run the 14t this year and add a lil more torque at the bottom end but be able to hit the rev limiter in 5th. I dont need a 70hp motor , just a lil tweeking.
Any Ideas ?
post #2 of 46 Old 02-09-2011, 06:29 PM
boost addict's Avatar
Intake and bored tb will get you through the rpms quicker.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #3 of 46 Old 02-09-2011, 06:29 PM
TRX700XXX's Avatar
Run 14T front and 38 rear sprockets, that should be inbetween just changing 13T and 14T front I think.
TRX700XXX is offline
post #4 of 46 Old 02-09-2011, 06:30 PM
I wonder how a Hot Cam Stage 3 would work with stock piston? I believe you would have to add new springs to your head but might be the boost in power you're looking for(lil tweak). :0)
post #5 of 46 Old 02-09-2011, 06:41 PM
08700xx's Avatar
I would say a cam and a +3 on the throttle body. From my research Web is the better cam but Hot Cams are cheaper. I know you ride a lot so having your bike down for the time it would take to get your throttle body done might not be an option for you, in that case you could do a CP 11:1 Piston and a cam.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #6 of 46 Old 02-09-2011, 06:45 PM
Simplyorange's Avatar
i did a stage 1 hotcam and a 11:1 piston, ill give you some feedback in bout a week.
2007 GSXR 1000 (Orange/Black)
Simplyorange is offline
post #7 of 46 Old 02-09-2011, 06:49 PM
The head is where all the power is hiding.
Ed @
Chris & Mike
post #8 of 46 Old 02-09-2011, 07:04 PM
With out doing major motorwork, I would just say a cam could help you out. Either a webcam or hotcam, I prefore hotcam as you don't have any core charges plus it is cheaper, however webcam has different angles and the stages are completely different btwn the two. I have been using hotcams since 2000 in my 99 400ex, and in everything pretty much since then, and no complaints. The cam will be about the cheapest and most reliable thing you could do, however I dont know who or where you could find a program. But however, like 08700xx said, a new cp piston w/ the cam could be nice. Stage 1 or 2 at the most though w/ the cam.
post #9 of 46 Old 02-09-2011, 07:14 PM
08700xx's Avatar
I agree
(DL700)
Jody (Boost Addict)
08700xx is offline
post #10 of 46 Old 02-09-2011, 09:45 PM
Full Exhaust, PC/Dobek, Air Filter & Stage one or two Cam.
If you go into the motor you can install that piston I gave you last year and run a stage three cam (Do you still have the piston?)
