Shaving the cylinder head - Club700XX - Honda TRX700XX Forum
post #1 of 48 Old 02-11-2011, 07:40 PM Thread Starter
Brokenbones's Avatar
With a cp 11:1 piston what the maximum i can shave out of the head to don't go past 11.5:1 and also without slamming the piston in the valves. Thank you!
Brokenbones is offline
post #2 of 48 Old 02-11-2011, 07:44 PM
boost addict's Avatar
Decking the head, that's a good question!
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #3 of 48 Old 02-11-2011, 08:18 PM Thread Starter
This is something we used to do on 400ex when we were poors teens
post #4 of 48 Old 02-11-2011, 08:31 PM
One thing you might want to look into is the timing chain it is a serious week spot on the 700xx motor. I raced with Matlock for a couple of years and his broke three times that I can think of. Alba racing sells a kit, but I am pretty sure its just the gears, chain, guides, and tensiener out of a 650r bike motor. You have to replace all the parts, but size difference is very noticeable, and worth doing.
fletch814 is offline
post #5 of 48 Old 02-11-2011, 08:38 PM
Thanks for the advice
Ed @
Chris & Mike
post #6 of 48 Old 02-11-2011, 09:09 PM Thread Starter
Yeah i seen this on their web site $$$$$$$ damn. I guess it's a good upgrade but i don't ride 1000 miles wide open but im much concerned about the tensioner...
post #7 of 48 Old 02-11-2011, 09:15 PM
08700xx's Avatar
Yes thank you for the advice/info. I guess I should do that upgrade now before it gives out on me.
Welcome to the club, glad to have you and your knowledge
(DL700)
Jody (Boost Addict)
08700xx is offline
post #8 of 48 Old 02-11-2011, 09:21 PM
09RappySE's Avatar
Quoted: 16 Post(s)
why do you want to do this? you deck the cylinder, not the head, you should'nt do this unless you head is warped.....or unless you want to reduce the combustion chamber size.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
post #9 of 48 Old 02-11-2011, 09:33 PM Thread Starter
The idea is to get more compression, about 11.5:1 with a cp 11:1 piston
post #10 of 48 Old 02-11-2011, 10:09 PM
09RappySE's Avatar
Quoted: 16 Post(s)
Correct...and you do that by decking the cylinder not the head.
734 09 Raptor
