Oils and lubes - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 02-15-2011, 10:25 PM Thread Starter
cjones0007's Avatar
Question Oils and lubes
Well its about that time for me to change EVERYTHING that keeps my 700xx running. What does everyone recommend for engine oil, chain lube, and coolant. As of right now im running Engine Ice? Pretty sure im going to stick with it, but does anyone disagree? Thanks, Chris.
2008 700xx
Full HMF Competition Series Exhaust.....HMF optimizer.....K&N Intake.....Kenda Kutters.....DG A-Arm Guards.....Pro Armor Skid plate.....Moto Activ Chivalry Bumper.....Moto Activ Extreme Nerf bars.....Custom Ostrich Skin Seat cover (Made by D&F Auto Sales & Service LLC.).....Shockwears.....Pro Grip Gel Grips.....EBC Clutch kit
cjones0007 is offline
post #2 of 8 Old 02-15-2011, 10:46 PM
Engine ice is good. I use honda gn4 dino oil and change it regularly. As for chain lube i like the belray.
post #3 of 8 Old 02-18-2011, 06:07 PM
should you change out your coolant after so long or just add when you get low?
WCMS is offline
post #4 of 8 Old 02-18-2011, 10:32 PM
I've never personally changed coolant because it was old, You could change it once per year if you wanted to be anal about maintenance though.
post #5 of 8 Old 02-20-2011, 12:00 PM
MizuriDirt's Avatar
Take a ph level test strip in your coolant and check it. If the level is acidic change it out. Otherwise if it looks good and it has the correct ph leave it alone.
MizuriDirt is offline
post #6 of 8 Old 02-20-2011, 03:52 PM
Regular gn4 motor oil and pj1 chain lube, I hear alot of good things about engine ice
post #7 of 8 Old 03-11-2011, 03:30 PM
just wonderin, and yea im pretty anal bout that stuff when you pay bout 7,000 for something, i probably baby it a little too much to. but ive never changed mine and really never thought bout it. ive only had to add once since i bought it.
WCMS is offline
post #8 of 8 Old 03-11-2011, 07:05 PM
Brokenbones's Avatar
Klotz mx4 true wonder
Brokenbones is offline
